Motor question- Emax RS2205 2300kv or Enax RS2205-S 2300kv ?
Hello,
I have been running the Lumenier 2206-11 2350 KV motor since I started flying a short time ago, Now that I am flying more aggressively, and losing to gravity every now and again, I am wondering if I went to a more cost friendly motor, which one would that be......?
I have found myself looking at the Emax Red Bottom RS2205 2300kv, but have also become aware of the RS2205-S 2300kv, does anyone have a recommendation between the two ?
Frame is a RR Alien 5 inch with KISS FC
Or is there another motor altogether, that is a little less expensive than the Lumenier ?
Thanks
Danny Z
So basically you want a better, less expensive motor. If I were to buy a new set of motors with more punch, I'd be getting the Armattan Oomph 2206-2300s. Just that they're not that cheap. Personally, I'm using the RMRC Rifle motors and they have tons of power but again not cheap
https://www.readymaderc.com/store/index....ts_id=6401
I use Emax RS2205S. They have some improvements over the "non S version" such as a hollow shaft and tighter tolerances with arched magnets for quicker response to throttle inputs.
I have been very pleased with their power and performance. Smile
The Obsession IS Real!
DOP,
How do the newer Emax motors affect your batteries, any noticeable negative effects ?
I was also checking out the Armattan motors that RENOV8R was mentioning
At this point, like everyone , I have too many choices, which is not a bad thing really, would love to just try them all !!!!!
I run the 2300Kv's and 1300mah 75c Tattu's.
If I am really pushing them hard (on Racekraft 5051x3 props) my lipos get quite warm but not hot, and I haven't had any puff yet either.
I would suspect the 2600Kv's to really stress those packs though.
But I have been quite pleased. Very aggressive flight times of 2.5-3 minutes. 4 to almost 5 minutes if I only cruise.
Check out the aokfly fire phonenix 2205 or 2306 motors on aliexpress. They are pretty cheap and from my experience a good value motor. I have 4 of the 2205 2500kv and 4 more on the way. According to miniquadtestbench they are performing about the same as the emax rs2205.
FIRE PHONENIX Purple red 2205 KV2300/2500 CW/CCW brushless Motors For FPV QAV250 quadcopter Multirotor Rc Model toys
http://s.aliexpress.com/6JvieURF
(from AliExpress Android)
New Arrival AOKFLY RV2306 2306 Motor 2400KV 2650KV CW CCW Motors For RC Drone FPV Racer Quadcopter Outdoor Toys
http://s.aliexpress.com/I3yMvMvm
http://www.miniquadtestbench.com/aokfly-...300kv.html
i fly those RS2205-S 2300kv almost a year now... cant kill them Smile
also depending on props you use you can go for either 2300 or 2600kv
what i like:
arc magnets - more powah and faster response
what i don't like:
one of the 5 is having some issues with screwing a nut and putting prop on...but nothing that a bit of brute force can't solve.
Konrad is flying on his Tornados and he is really happy with them, look at them as well.
All the best
Grzesiek (Grisha/ Greg)
thinking about building: 450
While I've had mixed feelings about my diatone ARF quad I can say that the motors on it are low-maintenance. In fact in contrast to my other quad I tend to come in too soon on batteries because I haven't used as much power as I thought I did.
http://www.diatoneusa.com/store/p241/Dia...00KV-motor
they're $20 a piece, which is around what some of the other suggestions seem to be, but they're still cheaper than the Lumeniers.
They are responsive, take it easy on battery, and are pretty much never more than a few degrees above ambient temperature after a flight.
carl.vegas
Thanks to everyone,
All awesome info, since I'm starting to fly .ore aggressive. The price point and the performance of the original emax red bottoms seem to be a good choice, at $15 each, that seems pretty good........
At least that is where I am leaning at the moment !!!
Stay tuned, I need to make a decision soon !!
Thank you again for all the great feed back !
Danny Z
[-] The following 1 user Likes DannyZ's post:
  • Drone0fPrey
  Help question on windows 11 roger74 4 325 15-Aug-2023, 11:51 AM
Last Post: roger74
  Betaflight Motor Test Results in SmokeStopper overvoltage LoganFPV 5 222 01-Aug-2023, 11:22 AM
  Help A question about range extenders... graywoulf 0 161 17-Jun-2023, 05:26 PM
Last Post: graywoulf
  Hang Time Question Bad Raven 15 510 06-Apr-2023, 02:06 PM
Last Post: mstc
  Build T-Motor F7 stack - Betaflight Gyro update frequency 3.2kHz ???? MindBenderFPV 2 3,020 18-Jun-2022, 09:10 AM
