Threads: 582
Likes Received: 8,921 in 6,600 posts
Likes Given: 1,425
786 It's nearly always the ESC or motors that fail and very rarely the FC, if at all. All the FC is responsible for is sending low voltage data bits over a serial connections to command the ESC what to do. So if you've already proven the motors are fine then it will 95% be the ESC which is the cause of the issues.
Threads: 44
Likes Received: 89 in 78 posts
Likes Given: 178
3 Cool, that's what I imagined. And I have seen this happen with RC airplanes and it's always the ESC. So it's similar I guess.
Threads: 172
Likes Given: 4,721
100 04-Mar-2024, 10:20 PM (This post was last modified: 04-Mar-2024, 10:23 PM by hugnosed_bat.) on a plane wizhout fc, its not simular in terms of throttle signal. in a rcplane the throttle is direct, on a quad the fc does apply throttle to single motors by our throttle input according the gyro data. there is a source for issues.
i would say an fc cant destroy a motor byself, but it can help :-) if there is an issue on more than one side, on the esc or motor the fc might be able to make it worse and fail sooner by wrong commands.
a high d-term value and overreacting quad, paired with a wrong startup value can cook motor, esc and fc at the same time. mainly a the startup/rampup value is very important.
on quad which should be as fast as possible, dterm can be a quad killer. its also dterm which let us fly like we are on rails, in the end its "performance request", not available, where danger is.
betaflight devs are healthcare, the brought us that crazy nice defaults. overfiltered but pretty no danger, only very uncommon builds or very very high performance does bring work for savety use on the defaults.
we went backward, from high gyro frequency rates up to 32khz on butterflight up to 8k/8k in bf. on the escs, dshot1200 was the plan once xD
today dshot600 is high, dshot300 does match more builds with the use of rpmfiltering. same on the khz frequency, commonly 4k/4k matches :-)
i believe we went from crazy innovations to rocksolid reliable system with good versatility.
