Threads: 2
Likes Received: 5 in 3 posts
Likes Given: 1
0 Hello everyone, I'm having a problem with my quad. When I arm my quad, one of my motors ( motor 3) spins faster then the rest. When I give it just a bit of throttle, that same motor spins to the maximum throttle. I tried calibrating them like follows; connected to cleanflight, on the motors tab I moved the rocker up, connected the battery. Waited for the beeps, put the rocker down and finished...
I have the Racerstar RS20Ax4 20A 4 in 1 escs.
I have also picked up the quad in the air and ran the motors, nothing.. I did a test flite today and it was horrible.. can't seem to findicate my solution.
Threads: 50
Likes Received: 704 in 450 posts
Likes Given: 1,189
30 Hm maybe try recalibrating again?
What motor protocol are you using? Are all escs on same firmware?
Threads: 66
Likes Received: 350 in 248 posts
Likes Given: 164
34 It is normal when arming the quad without props that some motors starts to spin faster and faster after giving some throttle. This is due to the I-term is increasing because of a small error setpoint deviation which the FC is trying to compensate for.
It could be bad calibration, but just be aware of the above as this will happen if you arm the quad without props
Threads: 66
Likes Given: 164
34 Try running the motors from the motor tab I betaflight instead to make sure the pid loop is not causing this issue
Threads: 2
Likes Given: 1
0 Thanks alot guys but my problem was my subtrims, they were not centered to 1500. As soon as I fixed them all. All my motors started runing the same speed..
