04-Aug-2016, 06:10 PM (This post was last modified: 04-Aug-2016, 07:59 PM by Bob Umerkulov.)
One of my friends asked me to build a quad for him and I got a chance to work with Motolab Cyclone FC v1.2
All wiring and extra stuff is sold separately, like this JST-SH wire and 2 spare connectors.
Specs:
Firmware
The FC comes with betaflight 2.9 already pre-flashed, but since 2.9.1 was released recently I flashed it. The process is pretty straightforward, but make sure you shorten boot pads when plugging in (with tweezers or similar) :
Also make sure that your connection settings are properly set in Betaflight Configurator:
Wiring
The first thing I noticed that there are no labels on the board at all. After googling a bit, found a wiring diagram:
Conclusion
If you're interested in initial betaflight configuration steps, I found those 2 videos extremely helpful:
Specs:
- An on-board 600mA switching regulator for direct connection to lipos up to 4S, or up to 6S with power filtering.
- USB interface independent of UART channels.
- Three hardware UARTs. The UART 2 TxD signal is also pinned out to a connector.
- Reverse current protection on lipo and USB inputs for problem-free ESC calibration.
- Dedicated serial LED output with lipo voltage and GND.
- On-board buzzer driver with 5V and lipo voltage option.
- Built-in VBAT monitor with low-pass filter from lipo input.
- Built-in RSSI monitor with low-pass filter.
- Dedicated SAT receiver interface with 3.3v using JST connector for compatibility with Spektrum/LemonRC cables.
- Dedicated PPM and serial receiver interfaces with 5V power using 0.1" headers.
- Compatibility with receivers using Spektrum 1024/2048, SBUS, SumD and SumH receivers with built-in inverter.
- High-quality gold plated 4-layer printed circuit board.
- Connector arrangement for convenient access to serial interfaces, with PWM and other device connections on sturdy through-hole pin headers.
Firmware
Wiring
Conclusion
- NO!!! dedicated 5v pins for each PWM output. Since most of racing ESC don't have a BEC there is no need to have an extra pin for each ESC.
- SPI protocol allowing faster gyro updates
- Build-in BEC for direct lipo connection
- 3 UART ports + USB VCP (virtual com port) allowing utilize UART1 fully.
- Labels..
- Having a separate spektrum sat. port is good, but not very necessary here. You should be able to connect it to any UART.
- Boot pins. Xracer F3 board has a super easy solution just having a small button compared to pin holes, which will be the way easier if you will be upgrading firmware having FC mounted on a quad already.
