MinimOSD flashing error - programmer is not responding
My minimosd was acting up so I decided to flash it.
Connected it using FT232RL, installed Arduino (1.6.7), installed FT driver - it discovers it fine.
Hooked it up to my laptop - the light blinks green for a while then Arduino spits out:
"avrdude: stk500_recv(): programmer is not responding"
If its not responding why is it blinking green?
Spent few hours on it already; no luck. Didnt find anything on the web that could help me. Tried different drivers - nothing. Board type is selected fine, so is the port.
Cable seem fine since its blinking green..
When I was rolling back the drivers to 2.10 I only did so for "USB Serial Port" and not "USB Serial Converter"
Did that now - no luck.
Anything else I could try?
Are the pins correct? have you tried swapping TX/RX?
Make sure the RST line is connected
Try to connect all the six wires
Try a different cable. Just because the lights are on, doesnt mean the signal wires are connected.
Follow this diagram:
[Image: NjWZrnml.jpg]
Tried all of the suggestions - still no luck.
I also tried this connection:
I'm guessing something is wrong with either the OSD board or the FT232.
I'm ordering a a new converter and micro miniosd (wanted to switch to micro anyways).
edit: bought a new micro minimOSD, and it worked! so it was the minimOSD unit I had that was faulty.
  Help MinimOSD with Pixhawk 2.4.8 EZDRONE 0 293 12-Jan-2022, 05:06 PM
Last Post: EZDRONE
Question Help Fpv error Petrouil 3 531 26-Feb-2020, 09:12 PM
  Help Micro MinimOSD displays Zeros raavhimself 0 1,057 15-Mar-2018, 10:51 AM
Last Post: raavhimself
  MinimOSD question rryyyaann 2 1,177 26-May-2017, 11:31 AM
Last Post: rryyyaann
  MinimOSD not displaying properly? JBFUK 5 2,274 16-May-2017, 12:05 PM
Last Post: JBFUK
