Micro won't lift off
I have just finished my build of a 110mm 2" micro.  I have, to my knowledge, completed all normal steps of configuration and flashing in both BLHeli and BetaFlight. However when I attempt to fly it, it will only lift off a few inches off the ground.
I've exhausted my research in relation to my knowledge in the hobby to solve this one and need the help of more experienced quad builders.
I've made sure that I eliminated most things that tend to be the cause (propellers on upside down or on the wrong motors, motors spinning the wrong direction, throttle max setting).
Below are my specs and my BetaFlight dump.
Any help or clues for what to further research are greatly appreciated!
Total listed weight: 95.49g
Specs:
Gens ace 7.4V 450mAh 2S LiPo Battery Pack 25C 28g
Frsky XM Plus Mini RX 1.6g
Makerfire 1935 2" props 2.72g
FuriousFPV 70mm 5G8 U.FL Linear Antenna .6g
RunCam Swift Micro 2 5.6g
Makerfire D1106 3800KV Brushless Motor 1-3S Racing Edition 26g
GEP HX2 Hummingbird 3inch Frame 110mm 17g
FuriBee Flytower Plus Mini F4 Flight Controller 9g
Eachine VTX03 Super Mini 5.8G 72CH 0/25mW/50mw/200mW Switchable FPV Transmitter 2.97g
Matek Systems 90dB 5V Loud Buzzer Lost Model Beeper 2g
BetaFlight Dump:
# Betaflight / OMNIBUSF4 3.1.7 Apr  3 2017 / 22:14:59 (e1c4b5c)
# name
name -
# resources
resource BEEPER 1 B04
resource MOTOR 1 B00
resource MOTOR 2 B01
resource MOTOR 3 A03
resource MOTOR 4 A02
resource MOTOR 5 A01
resource MOTOR 6 A08
resource MOTOR 7 NONE
resource MOTOR 8 NONE
resource MOTOR 9 NONE
resource MOTOR 10 NONE
resource MOTOR 11 NONE
resource MOTOR 12 NONE
resource SERVO 1 NONE
resource SERVO 2 NONE
resource SERVO 3 NONE
resource SERVO 4 NONE
resource SERVO 5 NONE
resource SERVO 6 NONE
resource SERVO 7 NONE
resource SERVO 8 NONE
resource PPM 1 B14
resource PWM 1 B14
resource PWM 2 B15
resource PWM 3 C06
resource PWM 4 C07
resource PWM 5 C08
resource PWM 6 C09
resource PWM 7 NONE
resource PWM 8 NONE
resource LED_STRIP 1 A01
resource SERIAL_TX 1 A09
resource SERIAL_TX 2 NONE
resource SERIAL_TX 3 B10
resource SERIAL_TX 4 NONE
resource SERIAL_TX 5 NONE
resource SERIAL_TX 6 C06
resource SERIAL_TX 7 NONE
resource SERIAL_TX 8 NONE
resource SERIAL_TX 9 NONE
resource SERIAL_TX 10 NONE
resource SERIAL_TX 11 NONE
resource SERIAL_TX 12 NONE
resource SERIAL_RX 1 A10
resource SERIAL_RX 2 NONE
resource SERIAL_RX 3 B11
resource SERIAL_RX 4 NONE
resource SERIAL_RX 5 NONE
resource SERIAL_RX 6 C07
resource SERIAL_RX 7 NONE
resource SERIAL_RX 8 NONE
resource SERIAL_RX 9 NONE
resource SERIAL_RX 10 NONE
resource SERIAL_RX 11 NONE
resource SERIAL_RX 12 NONE
# mixer
mixer QUADX
# servo
# servo mix
smix reset
feature -VBAT
feature -FAILSAFE
feature -SONAR
feature -CURRENT_METER
feature -OSD
feature -BLACKBOX
feature -TRANSPONDER
feature -AIRMODE
feature -SDCARD
feature -VTX
feature -RX_SPI
feature -SOFTSPI
feature -ESC_SENSOR
feature -FEATURE_ANTI_GRAVITY
feature VBAT
feature RX_SERIAL
feature FAILSAFE
feature OSD
# beeper
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
# map
map AETR1234
led 0 0,0::C:0
led 1 0,0::C:0
led 2 0,0::C:0
led 3 0,0::C:0
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 9
mode_color 5 1 11
mode_color 5 2 2
mode_color 5 3 13
mode_color 5 4 10
mode_color 5 5 3
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
mode_color 7 0 3
aux 0 0 0 1700 2100
aux 1 28 2 1700 2100
aux 2 1 2 900 1300
aux 3 2 2 1300 1700
aux 4 13 1 1700 2100
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
# adjrange
adjrange 0 0 0 900 900 0 0
adjrange 1 0 0 900 900 0 0
adjrange 2 0 0 900 900 0 0
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0
adjrange 12 0 0 900 900 0 0
adjrange 13 0 0 900 900 0 0
adjrange 14 0 0 900 900 0 0
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 8 h
rxfail 9 h
# master
set task_statistics = ON
set min_check = 1100
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 30
set rc_interp = AUTO
set rc_interp_ch = RP
set rc_interp_int = 19
set rssi_invert = OFF
set fpv_mix_degrees = 0
set max_aux_channels = 14
set debug_mode = NONE
set min_throttle = 1070
set max_throttle = 2000
set digital_idle_percent =  9.000
set use_unsynced_pwm = OFF
set motor_pwm_rate = 480
set disarm_kill_switch = ON
set small_angle = 25
set fixedwing_althold_dir = 1
set gps_provider = NMEA
set gps_sbas_mode = AUTO
set gps_auto_config = ON
set gps_auto_baud = OFF
set gps_wp_radius = 200
set nav_controls_heading = ON
set nav_speed_min = 100
set nav_speed_max = 300
set nav_slew_rate = 30
set beeper_inversion = ON
set beeper_od = OFF
set serialrx_provider = SBUS
set serialrx_halfduplex = OFF
set sbus_inversion = ON
set spektrum_sat_bind = 0
set spektrum_sat_bind_autorst = 1
set tlm_switch = OFF
set tlm_inversion = ON
set sport_halfduplex = ON
set frsky_default_lat =  0.000
set frsky_default_long =  0.000
set frsky_gps_format = 0
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set hott_alarm_int = 5
set pid_in_tlm = OFF
set ibus_report_cell_voltage = OFF
set bat_capacity = 0
set vbat_scale = 110
set vbat_hysteresis = 1
set ibat_scale = 400
set ibat_offset = 0
set mwii_ibat_output = OFF
set current_meter_type = ADC
set battery_meter_type = ADC
set bat_detect_thresh = 55
set use_vbat_alerts = ON
set use_cbat_alerts = OFF
set cbat_alert_percent = 10
set align_gyro = DEFAULT
set align_acc = DEFAULT
set align_mag = DEFAULT
set align_board_yaw = 0
set gyro_lpf = OFF
set gyro_sync_denom = 8
set gyro_isr_update = OFF
set gyro_use_32khz = OFF
set gyro_lowpass_type = PT1
set gyro_lowpass = 90
set gyro_notch1_hz = 400
set gyro_notch1_cut = 300
set gyro_notch2_hz = 200
set gyro_notch2_cut = 100
set moron_threshold = 48
set alt_hold_deadband = 40
set alt_hold_fast_change = ON
set deadband = 0
set yaw_deadband = 0
set thr_corr_value = 0
set thr_corr_angle = 800
set yaw_control_direction = 1
set yaw_motor_direction = 1
set servo_center_pulse = 1500
set tri_unarmed_servo = ON
set servo_lowpass_hz = 400
set servo_lowpass = OFF
set servo_pwm_rate = 50
set gimbal_mode = NORMAL
set airmode_start_throttle = 1350
set failsafe_delay = 10
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_procedure = DROP
set acc_hardware = AUTO
set acc_lpf_hz = 10
set accxy_deadband = 40
set accz_deadband = 40
set acc_unarmedcal = ON
set acc_trim_roll = 0
set baro_tab_size = 21
set baro_noise_lpf =  0.600
set baro_cf_vel =  0.985
set baro_cf_alt =  0.965
set baro_hardware = NONE
set mag_hardware = NONE
set mag_declination = 0
set pid_process_denom = 4
set blackbox_rate_num = 1
set blackbox_rate_denom = 1
set magzero_x = 0
set magzero_y = 0
set magzero_z = 0
set osd_units = IMPERIAL
set osd_rssi_alarm = 20
set osd_cap_alarm = 2200
set osd_time_alarm = 10
set osd_alt_alarm = 100
set osd_vbat_pos = 2060
set osd_rssi_pos = 2070
set osd_flytimer_pos = 2454
set osd_ontimer_pos = 2422
set osd_flymode_pos = 2412
set osd_throttle_pos = 129
set osd_vtx_channel_pos = 200
set osd_crosshairs = 0
set osd_horizon_pos = 200
set osd_current_pos = 97
set osd_mah_drawn_pos = 111
set osd_craft_name_pos = 396
set osd_gps_speed_pos = 66
set osd_gps_sats_pos = 386
set osd_altitude_pos = 161
set osd_pid_roll_pos = 322
set osd_pid_pitch_pos = 354
set osd_pid_yaw_pos = 386
set osd_power_pos = 47
set osd_pidrate_profile_pos = 418
set osd_battery_warning_pos = 200
set vcd_video_system = 0
set vcd_h_offset = 0
set vcd_v_offset = 0
# profile
set gps_pos_p = 15
set gps_pos_i = 0
set gps_pos_d = 0
set gps_posr_p = 34
set gps_posr_i = 14
set gps_posr_d = 53
set gps_nav_p = 25
set gps_nav_i = 33
set gps_nav_d = 83
set pidsum_limit =  0.500
set pidsum_limit_yaw =  0.500
set d_lowpass_type = BIQUAD
set d_lowpass = 100
set d_notch_hz = 260
set d_notch_cut = 160
set vbat_pid_gain = OFF
set pid_at_min_throttle = ON
set anti_gravity_thresh = 350
set anti_gravity_gain =  3.000
set setpoint_relax_ratio = 100
set d_setpoint_weight = 60
set yaw_accel_limit =  10.000
set accel_limit =  0.000
set iterm_windup = 50
set yaw_lowpass = 0
set p_pitch = 58
set i_pitch = 50
set d_pitch = 35
set p_roll = 44
set i_roll = 40
set d_roll = 30
set p_yaw = 70
set i_yaw = 45
set d_yaw = 20
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 50
set i_level = 50
set d_level = 100
set p_vel = 55
set i_vel = 55
set d_vel = 75
set level_sensitivity = 55
set level_limit = 55
# rateprofile
set rc_rate = 100
set rc_rate_yaw = 100
set rc_expo = 0
set rc_yaw_expo = 0
set thr_mid = 50
set thr_expo = 0
set roll_srate = 70
set pitch_srate = 70
set yaw_srate = 70
set tpa_rate = 10
set tpa_breakpoint = 1650
If it is able to lift few inches, that looks like it have not enough power to lift further. I had same symptoms on brushed quad when bad batteries used.
Feel like constantly chasing perfection. Once you think you almost got it, see how far you are really.
[-] The following 1 user Likes E.L.K.'s post:
  • shep
Small prop with low kv motor and only 2s?
[-] The following 1 user Likes flightmode0's post:
  • shep
Two things:
Please use [ code ] [ /code ] tags (without the spaces) around a CLI dump. It stops your message being many pages long.
3800kv with 2S and 1935 propellers will not generate enough lift for your quad to fly. If it's a 110mm quad, can't you fit larger propellers?
  • shep
The motors are likely not adequate, everything else seems robust enough. Your setup is lighter than my Lizzy 95 that has no issue with lifting and or flying with 1935 props. The motors on it are Eachine 1104/6000Kv and about the lowest Kv motors that are common. 3800Kv just seems so low.
SoCal Kaity :D
[-] The following 1 user Likes kaitylynn's post:
  • shep
(26-Nov-2017, 12:48 PM)unseen Wrote: Two things:
Thanks for the tip on the CLI dump.  I can't run anything larger.  There is right around 1/4" clearance between the front blades and front of the quad.
Thanks everyone! I'm going to pickup a 3S just to see how it does. After that, I'll switch out the motors.
Also, I would switch the props. If they are the same props I tried on my first build using 1104 6500kv motors, they were very lacking in thrust even on 3s with the higher kv.
Good luck and don't forget to post a picture of your build.  Wink
  • shep
You should be able to run 2" props on that setup.  It is about the same shape and size as KT-110 and I run GenFan 2045 props with enough clearance.  That also runs a 28 amp ESC with 7500Kv motors.  Originally started out with 6000Kv motors and it definitely has never has an issue jumping aloft.  It really seems you do not have enough motor to rise above the ground effect.
SoCal Kaity :D
  • shep
Here's what I have so far.  Still need to secure my RX antennas, but I'm still working on it.
Thanks again everyone!
Attached Files Thumbnail(s)
(26-Nov-2017, 06:09 PM)shep Wrote: Here's what I have so far.  Still need to secure my RX antennas, but I'm still working on it.
I use soda straws as antenna guides.  Some use coffee stirring straws.  Still others use zip ties and heat shrink tube.  There are a bunch of ways.  looking forward to seeing how you secure them!  Smile
SoCal Kaity :D
  • shep
(26-Nov-2017, 07:32 PM)kaitylynn Wrote: I use soda straws as antenna guides.  Some use coffee stirring straws.  Still others use zip ties and heat shrink tube.  There are a bunch of ways.  looking forward to seeing how you secure them!  Smile
I typically go the zip tie/heat shrink route, but haven't decided yet for this build.  The vtx antenna is done with hot glue along the antenna then heat shrink.  That method allows you to shape the antenna and even re-heat it to reshape.it.
[-] The following 2 users Like shep's post:
  • sloscotty, Oscar
(26-Nov-2017, 09:44 PM)shep Wrote: I typically go the zip tie/heat shrink route, but haven't decided yet for this build.  The vtx antenna is done with hot glue along the antenna then heat shrink.  That method allows you to shape the antenna and even re-heat it to reshape.it.
[youtube.com/watch?v=wfYZmh5Gsyo&t=332s]youtube.com/watch?v=wfYZmh5Gsyo&t=332s
Glad i see that video, should work great on the Runcam TX200 too!
(26-Nov-2017, 05:16 PM)kaitylynn Wrote: You should be able to run 2" props on that setup.  It is about the same shape and size as KT-110 and I run GenFan 2045 props with enough clearance.  That also runs a 28 amp ESC with 7500Kv motors.  Originally started out with 6000Kv motors and it definitely has never has an issue jumping aloft.  It really seems you do not have enough motor to rise above the ground effect.
His is 3800kv and not 6000kv.
#15
(27-Nov-2017, 03:24 AM)voodoo614 Wrote: His is 3800kv and not 6000kv.
Yes, as pointed out in my original response, #5.  Not enough motor with only 3800kv.  Was trying to illustrate that those props will definitely fly that model with 6000kv motors.
SoCal Kaity :D
  Solved SPI V3 ELRS won't bind nicetomeetyou 5 353 23-Feb-2024, 05:22 PM
Last Post: nicetomeetyou
  TBS CROSSFIRE Micro TX Eyes.fpv 7 222 09-Dec-2023, 12:04 PM
Last Post: Eyes.fpv
  Crossfire micro tx v2 problem when updating Keven741 4 1,589 02-Oct-2023, 11:15 AM
  yaw rotation at lift off der_huddel 2 216 04-Aug-2023, 06:03 PM
Last Post: der_huddel
Music Nazgul won't take off. Helltothena4093 3 227 12-Apr-2023, 06:03 PM
Last Post: Helltothena4093
