Posts: 5,315 Threads: 672 Likes Received: 3,155 in 1,743 posts Likes Given: 2,030 Joined: Jan 2016 Reputation: 139 19-Apr-2017, 02:53 PM (This post was last modified: 26-May-2017, 11:18 PM by Oscar.) The Micro Swift from Runcam is probably the lightest and smallest CCD FPV camera you can find on the market Perfect for micro quads as well as larger light weight racing builds. This could well be the new standard too for FPV cameras! Same performance as the Swift, but over 6g lighter. Spec: - 1/3″ SONY Super HAD II CCD
- 600TVL
- 2.1mm Lens (M8)
- PAL/NTSC
- Input voltage: DC 5V-36V
- Weight: 5.6g
- 19mm*19mm*19mm
Here is my review if you want to see some testing in the future: https://oscarliang.com/micro-swift-runcam/ Posts: 146 Threads: 75 Likes Received: 132 in 65 posts Likes Given: 38 Joined: Oct 2016 Reputation: 16 Wow impressive. I'm waiting your feedback. Do we need to send to you liquid tape? • Posts: 5,315 Threads: 672 Likes Received: 3,155 in 1,743 posts Likes Given: 2,030 Joined: Jan 2016 Reputation: 139 (19-Apr-2017, 03:54 PM)Pimousse Wrote: Wow impressive. I'm waiting your feedback. Do we need to send to you liquid tape? haha Already got it ! Posts: 1,070 Threads: 70 Likes Received: 742 in 378 posts Likes Given: 577 Joined: Jan 2016 Reputation: 44 Now thats an upgrade I wonder if that weight reduction only comes from decasing the mini and using a lighter lens. Hope you'll compare the boards side by side ^^ *cough* suggestion *cough* • Posts: 5,315 Threads: 672 Likes Received: 3,155 in 1,743 posts Likes Given: 2,030 Joined: Jan 2016 Reputation: 139 the lens is significantly smaller as well will have to take it apart and compare the bare PDB when it gets here • Posts: 2,286 Threads: 38 Likes Received: 1,527 in 995 posts Likes Given: 1,881 Joined: Apr 2016 Reputation: 72 Wow! A truly micro sized CCD camera! I really hope it's as good as we all want it to be. If it is, I can see rather a lot of micro CMOS cameras heading for the recycling bin. • Posts: 2,410 Threads: 136 Likes Received: 1,790 in 1,052 posts Likes Given: 3,302 Joined: Jan 2017 Reputation: 50 Awesome! I like how the case has normal tilt mounts too! • Posts: 5,315 Threads: 672 Likes Received: 3,155 in 1,743 posts Likes Given: 2,030 Joined: Jan 2016 Reputation: 139 20-Apr-2017, 06:33 PM (This post was last modified: 20-Apr-2017, 06:34 PM by Oscar.) (19-Apr-2017, 08:04 PM)KonradS Wrote: Now thats an upgrade I wonder if that weight reduction only comes from decasing the mini and using a lighter lens. Hope you'll compare the boards side by side ^^ *cough* suggestion *cough* so Konrad, you were right Mini and Micro use the same PCB left- swift2, middle - Mini, right - Micro Posts: 1,070 Threads: 70 Likes Received: 742 in 378 posts Likes Given: 577 Joined: Jan 2016 Reputation: 44 (20-Apr-2017, 06:33 PM)Oscar Wrote: Mini and Micro use the same PCB At last a partially interchangeable solution Do you have some insight on the final price? • Posts: 5,315 Threads: 672 Likes Received: 3,155 in 1,743 posts Likes Given: 2,030 Joined: Jan 2016 Reputation: 139 (20-Apr-2017, 08:12 PM)KonradS Wrote: At last a partially interchangeable solution Do you have some insight on the final price? $30 USD Posts: 1,070 Threads: 70 Likes Received: 742 in 378 posts Likes Given: 577 Joined: Jan 2016 Reputation: 44 (20-Apr-2017, 08:59 PM)Oscar Wrote: $30 USD • Posts: 2,410 Threads: 136 Likes Received: 1,790 in 1,052 posts Likes Given: 3,302 Joined: Jan 2017 Reputation: 50 21-Apr-2017, 01:41 AM (This post was last modified: 21-Apr-2017, 01:46 AM by Drone0fPrey.) Yeah thats sexy Im sold. Does the micro's lense fit in the mini's case? It'd keep the pcb covered and still save some weight over the Runcam Mini, in theory. Have some cake and eat it too haha • Posts: 5,315 Threads: 672 Likes Received: 3,155 in 1,743 posts Likes Given: 2,030 Joined: Jan 2016 Reputation: 139 21-Apr-2017, 09:29 AM (This post was last modified: 21-Apr-2017, 09:30 AM by Oscar.) Posts: 88 Threads: 5 Likes Received: 97 in 44 posts Likes Given: 66 Joined: Jun 2016 Reputation: 2 oh wow! I've been waiting for a camera like this for a long time! • Posts: 5,315 Threads: 672 Likes Received: 3,155 in 1,743 posts Likes Given: 2,030 Joined: Jan 2016 Reputation: 139 26-Apr-2017, 10:16 AM (This post was last modified: 26-Apr-2017, 10:17 AM by Oscar.) Update: Swift Mini and Micro PCB/Sensor are not interchangeable... on the Mini, the IR filter is applied on the sensor directly, while that of the Micro is on the lens. |
