If you've got a PDB with dedicated pins for Cam, Video, and OSD, you can use a really simplified wiring setup for your Micro MinimOSD. This is how I did it with my Demon Core V2.3.
(Part of the wiring diagram below is courtesy of kuerva at: http://www.xtremefpv.net/foro/viewtopic.php?t=308 . I added the FC with connections and I am using a different cam and vtx than shown.)
With the Demon Core 2.3 PDB, this setup works great! It has the required connections for Cam, VTx, and OSD, and all power outputs are selectable as 5 or 12 volts, and filtered. Following the rule-of-thumb: "1 ground per component", the MMOSD requires only 6 wires. The four supplied from the PDB, and Rx, Tx from the FC.
Tip 1: If your PDB has filtered power/ground connections for the OSD, use them - but get Vbat readings from the FC if possible. This keeps wiring to a minimum on the OSD (see diagram above). On my build, I supplied battery power to Vbat on the FC (Flip32), and set MWOSD to "Use FC main voltage".
_________________________________________________________
Because I wanted to be able to easily remove the MMOSD for programming or replacement, I soldered a pigtail with Male pins to Vid In/Out on the OSD, and Female plugs directly to Vid In/Out on the PDB. You could change the gender on these (or even "key" them), but I already had a strip of 3 plugs on the PDB for vtx, and Vid In/Out were next in line, so I just used a strip of 5 plugs.
Tip 2: Use a pigtail to connect Vid In/Out for easy removal. You could place plugs or pins on the OSD itself instead, but by soldering the Vid wires to the OSD (using plugs/pins on the PDB), it makes it easier to put heat-shrink around all of the OSD except the edge with the 5-pin header (see next tip).
_______________________________________________________________________________
Now, I knew I would need to flash the MMOSD and do initial configuration before first use, so I needed to install pins to connect to the FTDI programmer. Fortunately, 4 of the 5 pins needed could also be used for the connections to the PDB. I just needed one additional pin/plug for DTR from the programmer. Since I don't like to accidentally connect things wrong, I "keyed" the pin header by using Males for Tx, Rx, +5v, and Ground - and a Female for DTR. On the FTDI, I used opposite, mating pins/plugs.
Tip (and Trick) 3: Intall a (keyed optional) 5-pin header on the OSD and use +5v and Ground in that header for the power connection from the PDB (see wiring diagram). You don't need to use any of the other grounds on the OSD. I originally installed a pin on the end ground (on left in first photo), but later cut it off because it was not needed and in the way.
The next tip is not really specific to OSD wiring but should be followed when wiring in general. Take care not to create a situation where you can easily short live pins together.
Safety Tip 4: When using pins and plugs where power is involved, use Female plugs for "live" power headers or pigtails. I used Female header plugs soldered directly to the PDB for the vtx connection (mainly for ease of servicing). I soldered the camera pigtail directly to the PDB, and soldered a pigtail with Female plugs to +5v and ground on the PDB to supply power/ground for the OSD. In the photo below, near the top is the row for OSD, VTx, and Cam connections. From left to right: +5v and ground for OSD direct soldered (note - plugs not yet installed on ends), Vid in/out plugs for OSD, then 3 plugs for VTx (+12v in center), then direct soldered pigtail for Camera. Also notice the single pigtail (female plug) right below that for powering the FC.
_______________________________________________________________________________________
On the Flip32, the Tx/Rx for OSD shares the UART for USB. When OSD Tx/Rx is active you can't use the USB. I originally thought that the placement of my OSD would make it easy to "unplug" so that I could program the FC, but that turned out not to be the case. So I added a "switch" in the Tx line from the OSD (see wiring diagram). I couldn't find an actual small switch, so I made a jumper instead. I sprung the pins a bit to help the jumper stay snug, but if it does happen to fly off during flight, the video stream from the camera is not interrupted (and I have extra jumpers).
Trick (and Tip) 5: Put a switch in the OSD Tx line (see wiring diagram). A micro slider switch would be ideal, but if you haven't got one, make a jumper (and make an extra to keep in your flight kit). The photos below show mine (as well as the placement of the MMOSD in this tiny 130 size frame). [The "switch" pin header is secured to the FC with epoxy.]
Good luck with your Micro MinimOSD wiring setup!
Scotty
