Threads: 56
Likes Received: 335 in 196 posts
Likes Given: 183
15 well there is a weak point of this construction, look at the crystal.. it is standing on 2 legs and it is not supported with any touch of glue..
assuming that you would use it as gently as i'm (smack! Crash! ooops that was a tree?!)
such weakpoint will fall off and after 2-3 crashes it will be useless.
so as you will get one ensure that this "tube" is glued to something and will not fall off due to vibration.
All the best
Grzesiek (Grisha/ Greg)
Curently flyable: Nox 5, Minimalist 112
Bench / in progres: fixing Nox 3, Scrap
thinking about building: 450
Threads: 56
Likes Given: 183
15 hmmm sd cards in my experience are quite durable... and they have survived (so far) every crash (including water landing)
few things that im curious:
- does it record on power or you need to "click" record
- does it remember the last power setting or always you need to cycle from 0mw to ie 200
- image quality
All the best
