Micro brushed build.
[Image: alnwNqYl.jpg]
Frame: 3d printed from Thingiverse
http://www.thingiverse.com/thing:1221911
[Image: 832be2155cdcdc327818c795284aadd3_preview_featured.jpg]
Flight Controller: Micro Scisky
http://www.banggood.com/Micro-Scisky-32bits-Brushed-Flight-Control-Board-Based-On-Naze-32-For-Quadcopters-p-1002341.html
[Image: 1bf6ac64-201e-4077-8d2c-fb927eb2d8a4.jpg]
Motors: Cheapest Hubsan x4 8x20 i've found
http://www.ebay.com/itm/262203125031 (cca 2,5$ per pair)
*alternative: http://www.banggood.com/2-X-8x20mm-Motor-For-Hubsan-X4-H107C-H107D-RC-Quadcopter-p-87683.html (5,42 per pair)
[Image: s-l500.jpg]
Props:Walkera QR Ladybird
http://www.banggood.com/Wholesale-3-Set-Walkera-QR-Ladybird-Spare-Parts-Main-Blades-Propellers-QR-Ladybird-Z-01-p-47127.html
[Image: 20120619170045617.jpg]
Battery: Nano-tech 300mAh 45-90C (if you choose this battery, be careful of the polarity)
http://www.hobbyking.com/hobbyking/store...20300%2045
[Image: 26738.jpg]
Since I couldn't get Nanotechs, they were out of stock I chose these 30C batteries instead
5PCS Eachine H8 Mini H8 3D Battery 3.7V 260mAh RC Quadcopter Spare Parts
http://www.banggood.com/5PCS-Eachine-H8-Mini-H8-3D-Battery-3_7V-260mAh-RC-Quadcopter-Spare-Parts-p-987893.html
[Image: 02519ae0-0e53-4394-ad34-02a095d6c079.jpg]
FPV camera: 600TVL 1/4 1.8mm CMOS FPV 170 Degree Wide Angle Lens Camera
http://www.banggood.com/600TVL-1_8mm-CMOS-FPV-170-Degree-Wide-Angle-Lens-Camera-with-Diatone-Universal-Mini-Camera-Lens-p-1019753.html
[Image: SKU251677.1.jpg]
FPV Transmitter:FX758-2 5.8G 200mW 32CH FPV Wireless Audio Video AV Transmitter Module
http://www.banggood.com/FPV-5_8G-200mW-32CH-Wireless-Audio-Video-AV-Transmitter-Module-FX758-2-p-980317.html
[Image: SKU239291.1.jpg]
FPV 5.8GHz Micro CL TX Antenna Lightweight
http://www.banggood.com/FPV-5_8GHz-Micro-CL-TX-Anternna-0_8g-Lightweight-p-973291.html
[Image: SKU216683_2.jpg]
Dip switch 3p:
http://www.ebay.com/itm/181723891772
[Image: s-l1600.jpg]
Walkera Hubsan X4 Eachine H8 1 to 5 Balance Charging Cable For 3.7V Battery
http://www.banggood.com/Wholesale-Walkera-Hubsan-X4-Eachine-H8-1-to-5-Balance-Charging-Cable-For-3_7V-Battery-p-68437.html
[Image: sku064818.1.JPG]
Edit 14.04.2016: new information added
Edit 11.05.2016: new information added
Wow thats impressive whats the cost of that build
lol FPV
Ragg-e WBX 5"
BUILD
MY CHANNEL
At the moment of this writeup the prices are as follows (although you can click through links, and get them yourself Wink
Frame price depends on whether you have a 3d printer or you can source one, or have it made
  • Micro Scisky cleanflight capable FC: 32,99
  • 4x Hubsan x4 8x20 motors: 4,96
  • Walkera QR Ladybird props: 5,99
  • Nano-tech battery: 2,84
  • 600TVL 1/4 1.8mm CMOS camera :10,99
  • FX758-2 5.8G 200mW VTX: 11,16
Total: 68,93$
Haha yeah sorry i was at work so i didn't really have time to click through and take a look at all of the parts.
Thanks for listing the prices.
I may have to consider building one of these little things haha
lol FPV
Ragg-e WBX 5"
BUILD
MY CHANNEL
So, I've built it! Yay for me!
check it!
[Image: 2016-04-14.jpg]
Though I really need a good battery for it, its pretty heavy with all the stuff on it.
Its flashed with betaflight. I have a drifting problem, after some time it starts to drift to the right...
The drawback on the frame is that its hard to plug and unplug usb cable, as there is nothing keeping the FC in place.
the Scisky could really use a few mounting holes :/ Every time I'm unpluggin the usb I'm worried ill pull the FC out of the frame...
Also, the motors I've bought have really short leads, so that can be a problem...
Nothing like building it, to see what things could be better....
I've already started drawing an improved frame that will have the brackets for the FC, replacing fixed stand-offs with nylon ones, removing material where it should be removed so its lighter, etc...
Awesome Smile
I had a look at that frame on thingiverse, but found it a bit too heavy to my liking Smile
what's your total weight?
i don't know, dont have a precise scale... will use the kitchen one when i get home from work...
the frame I'm designing will be based on this one, but will be integral for all the things i have here so it should be much lighter, I'm planning on atleast 40% frame weight reduction
AUW is 59-60g. frame weight, the way i have it is 8-9g
That's reasonable Smile
BTW: The VTX doesn't come on  E band (Boscam) and to switch it to E band you have to de-solder the lid, and connect two pads like in this picture at position 1
[Image: 217357DSCF7453annoted.jpg][Image: 777443FX758E.jpg]
more info here
http://www.rcgroups.com/forums/showthread.php?t=2456116
i managed to do it by soldering a long wire across the pins, and then trimming the extra wire.... took me an hour, a magnifying glass and helluva good lighting, but i made it work Cool
Well guys, I've made it into an Instructable over here --> http://www.instructables.com/id/Small-an...uadcopter/
Check it out Big Grin also, vote for me in the contests Big Grin
  AOS 3" Toothpick build SeismicCWave 17 198 4 hours ago
Last Post: SeismicCWave
  CLI Dump for HGLRC Drashark 1S 1.6inch Micro Quad Oscar 1 601 23-Apr-2024, 08:08 PM
Last Post: segler999
  Build Meteor75 Build (Revision 4) :) Pathfinder075 9 580 14-Apr-2024, 03:28 AM
  3" 2S 1108 Build Pathfinder075 11 410 14-Apr-2024, 02:08 AM
  Build Armattan Tadpole 3" 2-3S Build brettbrandon 57 3,135 07-Apr-2024, 04:59 PM
