26-Dec-2021, 08:20 PM
Hi There
Can someone explain to me what mavlink is? I can't seem to find a solid definition of what it is and how it works. Does mavlink telemetry still work to its full capability at 50hz or only in the 150hz mode (ie can it be used for long range)? Also is mavlink only available when using the full sized tx? When using certain tbs receivers? Mavlink is different than the info on the OLED screens that the bigger crossfire modules have right?
The reason is I'm thinking of upgrading from my micro tx v2 to the lite or full sized module. I'm researching into a long range fixed wing build and have ideas of setting up an antenna tracker. But in order to use an antenna tracker it has to be paired with an autopilot/fc of the same brand (ie eagle tree fc with eagle tree aat, myflydream fc with myflydream aat, etc). This is when I found out that you can use "mavlink telemetry" to provide gps chords to an antenna tracker and get it to work with say an inav flight controller. In that case I would have to consider if the full-sized module would be better over the lite because of mavlink capabilities. I will come up with more questions but for now that's it.
Thanks
Thanks
