This one isn't too bad. You'll just jacks to cross over a wire on each side. It's better than the PDB that are all + on one side and all - on the other. Possibly better current handling this way and you get video poker filter. It also have the LC filter for the fpv gear, also if i don't think i will need with so short wiring.
Availalbe from Bang the good.
Description:
- Band name: Matek
- Item name: Matek Power Distribution Board
- Dimensions: 36 x 36mm
- Weight: About 6g
- Mounting holes 30.5mm square spacing
Features:
- 2oz copper & 4-layers PCB.
- ESC & Battery solder tabs in pairs.
- Solder Bridges of various voltage for Camera & VTX.
- DC/DC synchronous buck regulator, Efficiency is up to 95%.
- TVS(Transient Voltage Suppressor) protection for DC/DC chip.
- 5V & 12V Output LED indicators & Short circuit tolerant.
Specification:
General:
- Input voltage range (2S-6S operation): 7.2 - 26VDC
- Regulated 5V and 12V outputs
- LED power indicators ( 5V & 12V outputs )
- 4 ESC outputs
ESC outputs:
- Continuous current: 20A per output
- Peak current (10 seconds/minute): 30A per output
BEC 5V output:
- Designed for RC Receivers, Flight controllers, OSD, and Servos.
- Voltage: 5.0 +/- 0.1VDC
- Continuous current: 3 Amps
- Short-circuit tolerant (10 seconds/minute)
- LED (indicates voltage is in regulation, within 10%)
BEC 12V output:
- The battery should be 4S~6S LiPo
- Standard output designed to power cameras and video transmitters,etc.
- Voltage: 12.0 +/- 0.2VDC
- Continuous current: 2 Amps (Max.3A 10s/minute)
CAM & VTX voltage bridge
- 3S operation. choose “VCC” for 12V camera & 12V VTX, VCC=Battery Voltage.
- 4~6S operation, choose “12” for 12V camera & 12V VTX
- 3~6S operation, choose “5” for 5V camera
- Video pass through from the “CAM” pad to the “VTX” pad
Description:
- Band name: Matek
- Weight: About 6g
Features:
Specification:
General:
- 4 ESC outputs
ESC outputs:
BEC 5V output:
BEC 12V output:
