  • 2 Vote(s) - 4 Average
Matek Mini Power Hub PDB power distribution board
This one isn't too bad. You'll just jacks to cross over a wire on each side. It's better than the PDB that are all + on one side and all - on the other. Possibly better current handling this way and you get video poker filter. It also have the LC filter for the fpv gear, also if i don't think i will need with so short wiring.
[Image: 3oVXEwFl.jpg]
Availalbe from Bang the good.
Description:
- Band name: Matek
- Item name: Matek Power Distribution Board
- Dimensions: 36 x 36mm
- Weight: About 6g
- Mounting holes 30.5mm square spacing
Features:
- 2oz copper & 4-layers PCB.
- ESC & Battery solder tabs in pairs.
- Solder Bridges of various voltage for Camera & VTX.
- DC/DC synchronous buck regulator, Efficiency is up to 95%.
- TVS(Transient Voltage Suppressor) protection for DC/DC chip.
- 5V & 12V Output LED indicators & Short circuit tolerant.
Specification:
General:
- Input voltage range (2S-6S operation): 7.2 - 26VDC
- Regulated 5V and 12V outputs
- LED power indicators ( 5V & 12V outputs )
- 4 ESC outputs
ESC outputs:
- Continuous current: 20A per output
- Peak current (10 seconds/minute): 30A per output
BEC 5V output:
- Designed for RC Receivers, Flight controllers, OSD, and Servos.
- Voltage: 5.0 +/- 0.1VDC
- Continuous current: 3 Amps
- Short-circuit tolerant (10 seconds/minute)
- LED (indicates voltage is in regulation, within 10%)
BEC 12V output:
- The battery should be 4S~6S LiPo
- Standard output designed to power cameras and video transmitters,etc.
- Voltage: 12.0 +/- 0.2VDC
- Continuous current: 2 Amps (Max.3A 10s/minute)
CAM & VTX voltage bridge
- 3S operation. choose “VCC” for 12V camera & 12V VTX,  VCC=Battery Voltage.
- 4~6S operation, choose “12” for 12V camera & 12V VTX
- 3~6S operation, choose “5” for 5V camera
- Video pass through from the “CAM” pad to the “VTX” pad
  VTX Quanum Elite QE58-2 5.8GHz 25-200mW VTX: Bench Review & RF Power Measurements Michael Grabner 3 2,506 03-Jan-2024, 02:31 AM
  VTX tbs crsf/tracer - 1w vtx combo board for 49$ hugnosed_bat 25 3,564 02-Apr-2022, 11:53 AM
Last Post: kafie1980
  New Ardu compatible Matek F405 MiniTE FC versus 2 1,023 23-Mar-2022, 09:49 PM
Last Post: Lemonyleprosy
  Dynamic VTX power? versus 17 2,735 12-Mar-2022, 12:06 PM
  Accessory Flywoo I2C Barometer & Compass Board V-22 1 746 07-May-2021, 03:08 PM
Last Post: Oscar
