Makerfire MICRO FPV, the alternative to inductrix FPV
Presentation
The Makerfire Micro FPV is a small Quadricopter RC equipped with a system allowing the first-person view (FPV).
The device comes in a small box with pre-cut foam in the shape of the quad.
In terms of accessories you can count on
  • a lipo 1S 200mAh
  • USB cable for charging your Lipo
It is a device intended for DSMX protocol users. This is the protocol for Spektrum radio owners but also to Devo flashed Deviation.
In theory [Image: 1f609.svg] the model is BNF (bind and fly), simply pair your radio, connect the battery and fly.
Specifications
  • 64mm spacing engines.
  • 4 17500KV engines protected against shocks.
  • Flight duration: 3 minutes 40 seconds.
  • AIO 25mW 5.8G camera
The screw locations should be monitored, I'm not in the long run they do not will crack.
Weight: 22g (without LIPO)
Software
The Makerfire FPV Micro comes with version 3.0.1 of Betaflight SP Racing F3 evo already installed.
Logically you still have to binder with your radio quad. In this presentation I used the radio DX9.
The allocation process is very simple. Just press the bind button on the flight map and simultaneously connect lipo or USB.
Remember to correct your end points in the radio!
PID require a little time to adjust. I advise against the original ones!
Video
Conclusion
The Makerfire Micro FPV is a real alternative to Inductrix FPV in Spektrum. Firstly the cost is half (depending on specials) than the original product, on the other hand you will enjoy the benefits of a true flight map that will open, who knows, the doors of FPV Racing.
The protection of propellers are a must. It will monitor the scope and therefore the settings of your failsafe, because I had twice radios tops in the house.
The device is available here [Image: 1f449.svg] micro FPV
Good flights!
[-] The following 5 users Like Pimousse's post:
  • Terry, Oscar, BigglesFPV, Tom BD Bad, sloscotty
  CLI Dump for HGLRC Drashark 1S 1.6inch Micro Quad Oscar 1 600 Yesterday, 08:08 PM
Last Post: segler999
  First FPV build. 3.5" help Pums 4 174 04-Apr-2024, 03:23 PM
  Help Micro Quad flying easy but wobbling Harry1 46 1,395 13-Feb-2024, 10:18 PM
  GEPRC TinyGo for a first FPV quad? Scro 5 482 19-Dec-2023, 11:59 PM
Last Post: mstc
  Help GEPRC TinyGO 4K FPV Whoop RTF Controller issue aiflai 14 6,431 10-Dec-2023, 05:48 AM
Last Post: LEM17
