Mag and Baro not showing in cleanflight
Hello,
Thanks to a ton of help and advice from this forum I was able to get my flight controller connecting and flashed to the latest firmware.
HOWEVER: Once I connect the FC is working great from a gyro perspective however it is not highlighting the MAG/BARO options in the top.
I am using SPF3 Deluxe and running 2.0.1 firmware. I have tried reflashing the firmware and reconnecting. No luck. The quad shows the correct movement in the preview but the options are grey and the calibrate magnetometer is also grey.
Let me know what i need to do!
Thank you all
*EDIT - Also tried using betaflight and flashing to latest version 3.1.7 and I get the same results.
Mag and baro are disabled by default. Just go into the CLI to enable
[-] The following 2 users Like RENOV8R's post:
  • PaulMek, aziassassin
(21-Apr-2017, 02:51 AM)RENOV8R Wrote: Mag and baro are disabled by default.  Just go into the CLI to enable
WOW you are a life saver. I did a search on the cleanflight.md and found the below info. Can you tell me how I would know what to select?
MAG_HARDWARE
0 = Default, use whatever mag hardware is defined for your board type ;
1 = None, disable mag ;
2 = HMC5883 ;
3 = AK8975 ;
4 = AK8963
(for versions <= 1.7.1: 1 = HMC5883 ; 2 = AK8975 ; 3 = None, disable mag)
BARO_HARDWARE
1 = None,
2 = BMP085,
3 = MS5611,
4 = BMP280
*EDIT - I tried AUTO and then did a dump to confirm it took. It did so I disconnected and reconnected but still nothing...]
*EDIT2 - After reconnecting the changes did not save.... Looking into how to make it save now.
*EDIT# - Im a goof. I ran the save command and YAY ITS WORKING!! Thank you so much!
[-] The following 1 user Likes aziassassin's post:
  • sloscotty
Glad you got it figured out! Just watch your CPU load with all that shtuff turned on.
  • Drone0fPrey
Sad M10 GPS not showing in Betaflight Fuzzi 9 1,085 14-Jan-2024, 10:56 PM
Last Post: Coleon
  OSD not showing all the time Luizmazza 1 163 21-Dec-2023, 11:10 AM
  Anyone know if i could update a hyperion vengeance cleanflight 1.10 to betaflight? DethRattles 41 1,023 10-Dec-2023, 09:54 PM
Last Post: DethRattles
  Turnigy evolution pro flight switch issues and switching from cleanflight 1.2.4 DethRattles 6 329 28-Nov-2023, 06:04 AM
  F210-3D / CleanFlight Coleon 10 858 13-Oct-2023, 01:08 PM
