M9-R gimbal throw degree
Hey guys, any of you using M9-R Racing gimbals?
I have the regular M9 gimbals, but I still miss the shorter throw of Spektrum gimbals.
I read somewhere that the standard M9 gimbals have a travel of 60 degrees. Supposedly these are 45 degrees. Even though the description in the product only mentions throttle, I’m going to have to guess it applies to all axes, right?
I asked Frsky directly, and they said:
"45 degree travel only apply to throttle. We will have another red panel M9 which is compatible with M9R, so you don't need to buy two of M9-R"
I was hoping the entire thing had shorter throws, like Spektrum. I have M9 gimbals on my Taranis too, and throws are long, like on the original FrSky gimbals. If they are slightly shorter, they are still way longer than Spektrum. IMO No use of getting it if it's just for throttle, M9 are good enough for now.
  Neat gimbal mod for the Boxer... skywanderer 4 699 05-Aug-2023, 04:36 PM
  Tip & Trick TX16s gimbal mod truglodite 1 531 01-Aug-2023, 08:50 PM
Last Post: Lemonyleprosy
  Dji digital remote Radio Master AG01 gimbal mod o0MerK0o 2 748 24-Oct-2022, 05:26 AM
Last Post: o0MerK0o
  How do I adjust the Throttle gimbal tension on a RadioMaster TX16S? cam94z28 3 5,599 29-Jan-2022, 06:13 PM
Last Post: Flying Dutchman
  Help Taranis QX7s gimbal issue SaHaRzZz 4 971 02-Jul-2021, 11:24 AM
Last Post: SaHaRzZz
