Lumenier 5x5x3 "Butter Cutter" Props
Lumenier has been making some great props lately and the latest of these is there 5x5x3 "Butter Cutters" They look like pretty awesome props!
The Lumenier 5x5x3 Butter Cutter propeller is designed for high speed and extreme performance. This unique airfoil provides incredible thrust throughout the entire power-band, and especially the top end. In addition to incredible power potential, the Butter Cutter also has great efficiency. Most high performance propellers suffer from high amp draw to achieve top-end thrust, but the Butter Cutter's advanced airfoil allows for both high performance and good efficiency. These props give you a "locked in" feel while flying and really grip the air while cornering.
The Butter Cutter propellers are made from an ultra-durable, crash resistant polycarbonate material. This allows the propellers to resist breaking in a crash or prop strike. Now you can clip a gate or a tree branch and keep flying! Each blade is 100% balanced direct from the mold as well, giving you a "butter smooth" flight.
FPV Drone Racing and Freestyle flying require high-quality propellers that ensure optimal thrust, efficiency and top-end speed to allow pilots to consistently perform at their best. Lumenier prop design starts from the ground up, considering flight speed, blade RPM and other factors to optimize each profile. Leveraging a proprietary algorithm, each prop has a unique airfoil and blade design, rather than using the same blade and duplicating them on double, triple or quad-bladed props. This leads to subtle, yet important, performance improvements that can mean the difference between a win or a DNF on race day.
[-] The following 1 user Likes Xtopher98's post:
  • Oscar
  Tinyhawk III props PSA Rob Axel 7 371 24-Mar-2024, 09:38 PM
Last Post: husafreak
  Foldable Props Oscar 21 2,771 08-Feb-2023, 07:53 PM
Last Post: BadRaven
  Prop New Racing Props from APC sloscotty 1 545 30-Sep-2020, 08:50 PM
Last Post: montis
  Prop Gemfan is making their own version of fold props too Oscar 8 1,004 18-Jul-2020, 11:46 PM
  ESC New Lumenier 32bit Silk ESCs Ahmad Ilyas 7 4,797 15-Jun-2019, 07:45 PM
Last Post: Green_Weedle
