I feel a big space between zero throttle and motors start to spin I don't know what is the name of that and how to change that but I want reduce this space, I want that if I just move just a little the throttle the motors start to spin, how can I solve this?
Lowest throttle not low enough? |
02-Nov-2017, 08:39 PM You could try min_check if you are on Betaflight. https://github.com/betaflight/betaflight...ick-inputs- 02-Nov-2017, 08:41 PM Set min_check to 1005 if you have good radio and all be good. By default it's as I remember 1100 so 100 units are wasted. It's default min_check at 1100. Before you reach 1100 on your Tx sticks there's a deadzone. |
Quad fall of the sky when doing small throttle move | Snyfir | 11 | 630 | 09-Sep-2023, 10:28 PM Last Post: hugnosed_bat | |
Cineon C30 fall of the sky when doing rapid throttle move | Snyfir | 5 | 434 | 04-Jun-2023, 06:28 PM Last Post: Lemonyleprosy | |
“Floaty” drop throttle not responding issue | Rob Axel | 0 | 245 | 13-Jan-2023, 03:06 PM Last Post: Rob Axel | |
High KV motor with 6s Pack and Throttle Limit | thrasher7811 | 14 | 9,129 | 22-Aug-2022, 07:15 AM Last Post: romangpro | |
230mm quad throttle issues. | VarthDader | 0 | 369 | 28-Mar-2022, 08:54 PM Last Post: VarthDader |
