Threads: 3
Likes Received: 1 in 1 posts
0 I just bought T-Motor 200 combo air gear 2205 2650KV. The manufacture says that at 100% throttle using DAL Prop the current flow is 27,4A. unfortunately (i think) i also have bought Little bee esc 20A. So the question is what will happen if i combine that parts? Should i change the esc with 30A?
Thank you and have a nice day!
Threads: 38
Likes Given: 1,881
72 If that 27.4A comes from a static thrust test, then you'll be fine with 20A ESCs.
Actual current is normally 25 - 35% lower than what a static thrust test shows.
Threads: 3
0 Oke thanks a lot all of you
