Posts: 164 Threads: 36 Likes Received: 83 in 46 posts Likes Given: 124 Joined: May 2017 Reputation: 4 Guys everytime I drop my throttle my PIDS go all crazy. I'm getting a pretty constant wobble as well. I know a lot more info is needed but off the cuff what do you all think? http://imgur.com/a/fsa1W Quads: RealACC X6R ; RealACC X210 Pro, Omnifbus F3 FCs; RunCam Swift 2 & Swift 2 Rotor Riot, Emax OG Red Bottoms, Emax RS2205S 2300kv; Fatshark DOM V3 YouTube - Mr.E_fPv • Posts: 5,315 Threads: 672 Likes Received: 3,155 in 1,743 posts Likes Given: 2,030 Joined: Jan 2016 Reputation: 139 maybe you can just post your blackbox log? can't tell much just from that screenshot Posts: 164 Threads: 36 Likes Received: 83 in 46 posts Likes Given: 124 Joined: May 2017 Reputation: 4 12-Jun-2017, 02:52 AM (This post was last modified: 12-Jun-2017, 04:49 AM by rryyyaann.) What could cause the PIDS to be dropping out every time the throttle is low. As long as i stay on the throttle its pretty locked in. I am in Airmode too. I don't have any blackbox from my latest tune it helps to have the SD card installed in the FC, duh. UPDATE: Here's the most recent Black Box Black Box THANKS Quads: RealACC X6R ; RealACC X210 Pro, Omnifbus F3 FCs; RunCam Swift 2 & Swift 2 Rotor Riot, Emax OG Red Bottoms, Emax RS2205S 2300kv; Fatshark DOM V3 YouTube - Mr.E_fPv • Posts: 2,286 Threads: 38 Likes Received: 1,527 in 995 posts Likes Given: 1,881 Joined: Apr 2016 Reputation: 72 I really don't understand how you have this craft tuned.... These PID values seem to be ridiculously high. I'm not sure what you mean by "PIDs dropping out". • Posts: 5,315 Threads: 672 Likes Received: 3,155 in 1,743 posts Likes Given: 2,030 Joined: Jan 2016 Reputation: 139 LOL... yea those PID values are a bit extreme... I will take a look at the BB log when I get home • Posts: 1,773 Threads: 30 Likes Received: 1,199 in 755 posts Likes Given: 714 Joined: Oct 2016 Reputation: 45 I wouldn't fly until you get some input from Oscar. Those D settings on pitch and roll are quite high, I'm guessing your motors are getting pretty hot? • Posts: 5,315 Threads: 672 Likes Received: 3,155 in 1,743 posts Likes Given: 2,030 Joined: Jan 2016 Reputation: 139 PID are way way way too high ! Try this values instead for the start Roll P 55 I 45 D 20 Pitch P 65 I 55 D 25 Yaw P 90 report back if you can Play with Set Point weight (0.7-1.0) before further changing D Your quad is pretty clean of noise, so it should fly relatively nice and you are lucky you haven't burned your motors yet LOL Posts: 164 Threads: 36 Likes Received: 83 in 46 posts Likes Given: 124 Joined: May 2017 Reputation: 4 13-Jun-2017, 12:37 AM (This post was last modified: 13-Jun-2017, 12:43 AM by rryyyaann.) (13-Jun-2017, 12:11 AM)Oscar Wrote: PID are way way way too high ! Try this values instead for the start Roll P 55 I 45 D 20 Pitch P 65 I 55 D 25 Yaw P 90 report back if you can Play with Set Point weight (0.7-1.0) before further changing D Your quad is pretty clean of noise, so it should fly relatively nice and you are lucky you haven't burned your motors yet LOL Thanks for the info! I'll give these values a try and adjust the set point weight of D. Trust me I understand what you're saying. I have had very similar PIDS to what you have suggested and the thing flies like garbage. My motors aren't even getting a little warm which also surprised me. So I just kept cranking things up and up. I dont get it. It's probably just time to get new motors. The esc maybe have 10 flights on them. The board was just installed Saturday. Everything sounds smooth but who knows. Its a ZMR250 Emax 2204 2300kv motors Little Bee 20a opto ESC Omnibus F3 FC HQ 5x4x3 Quads: RealACC X6R ; RealACC X210 Pro, Omnifbus F3 FCs; RunCam Swift 2 & Swift 2 Rotor Riot, Emax OG Red Bottoms, Emax RS2205S 2300kv; Fatshark DOM V3 YouTube - Mr.E_fPv • Posts: 164 Threads: 36 Likes Received: 83 in 46 posts Likes Given: 124 Joined: May 2017 Reputation: 4 (12-Jun-2017, 10:47 AM)unseen Wrote: I really don't understand how you have this craft tuned.... These PID values seem to be ridiculously high. I'm not sure what you mean by "PIDs dropping out". Dropping out isn't the right way to say it. When I let off the throttle control sloppy and the quad bumps around like the PIDS arent doing anything. Get back on the throttle things are better. This is not my only quad. MY x210 is tuned pretty solid and flies great. Quads: RealACC X6R ; RealACC X210 Pro, Omnifbus F3 FCs; RunCam Swift 2 & Swift 2 Rotor Riot, Emax OG Red Bottoms, Emax RS2205S 2300kv; Fatshark DOM V3 YouTube - Mr.E_fPv • Posts: 5,315 Threads: 672 Likes Received: 3,155 in 1,743 posts Likes Given: 2,030 Joined: Jan 2016 Reputation: 139 • Posts: 164 Threads: 36 Likes Received: 83 in 46 posts Likes Given: 124 Joined: May 2017 Reputation: 4 (13-Jun-2017, 01:04 AM)Oscar Wrote: you are using 4S right? Yeah 1300 4S Quads: RealACC X6R ; RealACC X210 Pro, Omnifbus F3 FCs; RunCam Swift 2 & Swift 2 Rotor Riot, Emax OG Red Bottoms, Emax RS2205S 2300kv; Fatshark DOM V3 YouTube - Mr.E_fPv • Posts: 2,410 Threads: 136 Likes Received: 1,790 in 1,052 posts Likes Given: 3,302 Joined: Jan 2017 Reputation: 50 What is your min_throttle set to? Could it be too low and allowing the props to slow too much? • Posts: 164 Threads: 36 Likes Received: 83 in 46 posts Likes Given: 124 Joined: May 2017 Reputation: 4 13-Jun-2017, 11:20 AM (This post was last modified: 13-Jun-2017, 01:17 PM by rryyyaann.) (13-Jun-2017, 07:31 AM)Drone0fPrey Wrote: What is your min_throttle set to? Could it be too low and allowing the props to slow too much? DOP that's a good thought just checked it an Min is at 1065
I'm going to try Oscar's suggested PIDS this morning and report back with the blackbox. Thanks for all the help! UPDATE: Here is the latest blackbox using Oscar's suggested PIDS. I dont know what the heck is happening. BlackBox Code: CLI # dump # Betaflight / OMNIBUS 3.1.7 Apr 3 2017 / 22:14:20 (e1c4b5c) name Mr.E_Fpv resource BEEPER 1 C15 resource MOTOR 1 B08 resource MOTOR 2 B09 resource MOTOR 3 A03 resource MOTOR 4 A02 resource MOTOR 5 B07 resource MOTOR 6 B06 resource MOTOR 7 NONE resource MOTOR 8 NONE resource MOTOR 9 NONE resource MOTOR 10 NONE resource MOTOR 11 NONE resource MOTOR 12 NONE resource SERVO 1 NONE resource SERVO 2 NONE resource SERVO 3 NONE resource SERVO 4 NONE resource SERVO 5 NONE resource SERVO 6 NONE resource SERVO 7 NONE resource SERVO 8 NONE resource PPM 1 B04 resource PWM 1 NONE resource PWM 2 NONE resource PWM 3 NONE resource PWM 4 NONE resource PWM 5 NONE resource PWM 6 NONE resource PWM 7 NONE resource PWM 8 NONE resource LED_STRIP 1 A08 resource SERIAL_TX 1 A09 resource SERIAL_TX 2 A14 resource SERIAL_TX 3 B10 resource SERIAL_TX 4 NONE resource SERIAL_TX 5 NONE resource SERIAL_TX 6 NONE resource SERIAL_TX 7 NONE resource SERIAL_TX 8 NONE resource SERIAL_TX 9 NONE resource SERIAL_TX 10 NONE resource SERIAL_TX 11 NONE resource SERIAL_TX 12 NONE resource SERIAL_RX 1 A10 resource SERIAL_RX 2 A15 resource SERIAL_RX 3 B11 resource SERIAL_RX 4 NONE resource SERIAL_RX 5 NONE resource SERIAL_RX 6 NONE resource SERIAL_RX 7 NONE resource SERIAL_RX 8 NONE resource SERIAL_RX 9 NONE resource SERIAL_RX 10 NONE resource SERIAL_RX 11 NONE resource SERIAL_RX 12 NONE mixer QUADX mmix reset servo 0 1000 2000 1500 90 90 100 -1 servo 1 1000 2000 1500 90 90 100 -1 servo 2 1000 2000 1500 90 90 100 -1 servo 3 1000 2000 1500 90 90 100 -1 servo 4 1000 2000 1500 90 90 100 -1 servo 5 1000 2000 1500 90 90 100 -1 servo 6 1000 2000 1500 90 90 100 -1 servo 7 1000 2000 1500 90 90 100 -1 smix reset feature -RX_PPM feature -VBAT feature -INFLIGHT_ACC_CAL feature -RX_SERIAL feature -MOTOR_STOP feature -SERVO_TILT feature -SOFTSERIAL feature -GPS feature -FAILSAFE feature -SONAR feature -TELEMETRY feature -CURRENT_METER feature -3D feature -RX_PARALLEL_PWM feature -RX_MSP feature -RSSI_ADC feature -LED_STRIP feature -DISPLAY feature -OSD feature -BLACKBOX feature -CHANNEL_FORWARDING feature -TRANSPONDER feature -AIRMODE feature -SDCARD feature -VTX feature -RX_SPI feature -SOFTSPI feature -ESC_SENSOR feature -FEATURE_ANTI_GRAVITY feature VBAT feature RX_SERIAL feature FAILSAFE feature CURRENT_METER feature OSD feature BLACKBOX feature SDCARD beeper GYRO_CALIBRATED beeper RX_LOST beeper RX_LOST_LANDING beeper DISARMING beeper ARMING beeper ARMING_GPS_FIX beeper BAT_CRIT_LOW beeper BAT_LOW beeper GPS_STATUS beeper RX_SET beeper ACC_CALIBRATION beeper ACC_CALIBRATION_FAIL beeper READY_BEEP beeper MULTI_BEEPS beeper DISARM_REPEAT beeper ARMED beeper SYSTEM_INIT beeper ON_USB map TAER1234 serial 20 1 115200 57600 0 115200 serial 0 0 115200 57600 0 115200 serial 1 0 115200 57600 0 115200 serial 2 64 115200 57600 0 115200 led 0 0,0::C:0 led 1 0,0::C:0 led 2 0,0::C:0 led 3 0,0::C:0 led 4 0,0::C:0 led 5 0,0::C:0 led 6 0,0::C:0 led 7 0,0::C:0 led 8 0,0::C:0 led 9 0,0::C:0 led 10 0,0::C:0 led 11 0,0::C:0 led 12 0,0::C:0 led 13 0,0::C:0 led 14 0,0::C:0 led 15 0,0::C:0 led 16 0,0::C:0 led 17 0,0::C:0 led 18 0,0::C:0 led 19 0,0::C:0 led 20 0,0::C:0 led 21 0,0::C:0 led 22 0,0::C:0 led 23 0,0::C:0 led 24 0,0::C:0 led 25 0,0::C:0 led 26 0,0::C:0 led 27 0,0::C:0 led 28 0,0::C:0 led 29 0,0::C:0 led 30 0,0::C:0 led 31 0,0::C:0 color 0 0,0,0 color 1 0,255,255 color 2 0,0,255 color 3 30,0,255 color 4 60,0,255 color 5 90,0,255 color 6 120,0,255 color 7 150,0,255 color 8 180,0,255 color 9 210,0,255 color 10 240,0,255 color 11 270,0,255 color 12 300,0,255 color 13 330,0,255 color 14 0,0,0 color 15 0,0,0 mode_color 0 0 1 mode_color 0 1 11 mode_color 0 2 2 mode_color 0 3 13 mode_color 0 4 10 mode_color 0 5 3 mode_color 1 0 5 mode_color 1 1 11 mode_color 1 2 3 mode_color 1 3 13 mode_color 1 4 10 mode_color 1 5 3 mode_color 2 0 10 mode_color 2 1 11 mode_color 2 2 4 mode_color 2 3 13 mode_color 2 4 10 mode_color 2 5 3 mode_color 3 0 8 mode_color 3 1 11 mode_color 3 2 4 mode_color 3 3 13 mode_color 3 4 10 mode_color 3 5 3 mode_color 4 0 7 mode_color 4 1 11 mode_color 4 2 3 mode_color 4 3 13 mode_color 4 4 10 mode_color 4 5 3 mode_color 5 0 9 mode_color 5 1 11 mode_color 5 2 2 mode_color 5 3 13 mode_color 5 4 10 mode_color 5 5 3 mode_color 6 0 6 mode_color 6 1 10 mode_color 6 2 1 mode_color 6 3 0 mode_color 6 4 0 mode_color 6 5 2 mode_color 6 6 3 mode_color 6 7 6 mode_color 6 8 0 mode_color 6 9 0 mode_color 6 10 0 mode_color 7 0 3 aux 0 0 0 1700 2100 aux 1 28 1 900 1300 aux 2 4 3 1300 1700 aux 3 27 2 900 1300 aux 4 0 0 900 900 aux 5 0 0 900 900 aux 6 0 0 900 900 aux 7 0 0 900 900 aux 8 0 0 900 900 aux 9 0 0 900 900 aux 10 0 0 900 900 aux 11 0 0 900 900 aux 12 0 0 900 900 aux 13 0 0 900 900 aux 14 0 0 900 900 aux 15 0 0 900 900 aux 16 0 0 900 900 aux 17 0 0 900 900 aux 18 0 0 900 900 aux 19 0 0 900 900 adjrange 0 0 0 900 900 0 0 adjrange 1 0 0 900 900 0 0 adjrange 2 0 0 900 900 0 0 adjrange 3 0 0 900 900 0 0 adjrange 4 0 0 900 900 0 0 adjrange 5 0 0 900 900 0 0 adjrange 6 0 0 900 900 0 0 adjrange 7 0 0 900 900 0 0 adjrange 8 0 0 900 900 0 0 adjrange 9 0 0 900 900 0 0 adjrange 10 0 0 900 900 0 0 adjrange 11 0 0 900 900 0 0 adjrange 12 0 0 900 900 0 0 adjrange 13 0 0 900 900 0 0 adjrange 14 0 0 900 900 0 0 rxrange 0 1000 2000 rxrange 1 1000 2000 rxrange 2 1000 2000 rxrange 3 1000 2000 rxfail 0 a rxfail 1 a rxfail 2 a rxfail 3 a rxfail 4 h rxfail 5 h rxfail 6 h rxfail 7 h rxfail 8 h rxfail 9 h rxfail 10 h rxfail 11 h rxfail 12 h rxfail 13 h rxfail 14 h rxfail 15 h rxfail 16 h rxfail 17 h set task_statistics = ON set mid_rc = 1500 set min_check = 1100 set max_check = 1900 set rssi_channel = 9 set rssi_scale = 30 set rc_interp = AUTO set rc_interp_ch = RP set rc_interp_int = 19 set rssi_invert = OFF set input_filtering_mode = OFF set fpv_mix_degrees = 0 set max_aux_channels = 14 set debug_mode = NONE set min_throttle = 1020 set max_throttle = 2000 set min_command = 1000 set digital_idle_percent = 4.500 set 3d_deadband_low = 1406 set 3d_deadband_high = 1514 set 3d_neutral = 1460 set 3d_deadband_throttle = 50 set use_unsynced_pwm = OFF set motor_pwm_protocol = ONESHOT125 set motor_pwm_rate = 480 set disarm_kill_switch = ON set gyro_cal_on_first_arm = OFF set auto_disarm_delay = 5 set small_angle = 25 set fixedwing_althold_dir = 1 set reboot_character = 82 set serial_update_rate_hz = 100 set beeper_inversion = ON set beeper_od = OFF set serialrx_provider = SPEK2048 set sbus_inversion = ON set spektrum_sat_bind = 0 set spektrum_sat_bind_autorst = 1 set tlm_switch = OFF set tlm_inversion = ON set sport_halfduplex = ON set frsky_default_lat = 0.000 set frsky_default_long = 0.000 set frsky_gps_format = 0 set frsky_unit = IMPERIAL set frsky_vfas_precision = 0 set frsky_vfas_cell_voltage = OFF set hott_alarm_int = 5 set pid_in_tlm = OFF set bat_capacity = 0 set vbat_scale = 113 set vbat_max_cell_voltage = 43 set vbat_min_cell_voltage = 33 set vbat_warning_cell_voltage = 35 set vbat_hysteresis = 1 set ibat_scale = 252 set ibat_offset = 56 set mwii_ibat_output = OFF set current_meter_type = VIRTUAL set battery_meter_type = ADC set bat_detect_thresh = 55 set use_vbat_alerts = ON set use_cbat_alerts = OFF set cbat_alert_percent = 10 set align_gyro = DEFAULT set align_acc = DEFAULT set align_mag = DEFAULT set align_board_roll = 0 set align_board_pitch = 0 set align_board_yaw = -180 set gyro_lpf = OFF set gyro_sync_denom = 1 set gyro_isr_update = OFF set gyro_use_32khz = OFF set gyro_lowpass_type = PT1 set gyro_lowpass = 90 set gyro_notch1_hz = 0 set gyro_notch1_cut = 300 set gyro_notch2_hz = 0 set gyro_notch2_cut = 100 set moron_threshold = 48 set imu_dcm_kp = 2500 set imu_dcm_ki = 0 set alt_hold_deadband = 40 set alt_hold_fast_change = ON set deadband = 1 set yaw_deadband = 3 set thr_corr_value = 0 set thr_corr_angle = 800 set yaw_control_direction = 1 set yaw_motor_direction = 1 set servo_center_pulse = 1500 set tri_unarmed_servo = ON set servo_lowpass_hz = 400 set servo_lowpass = OFF set servo_pwm_rate = 50 set gimbal_mode = NORMAL set channel_forwarding_start = 4 set airmode_start_throttle = 1350 set failsafe_delay = 17 set failsafe_off_delay = 10 set failsafe_throttle = 180 set failsafe_kill_switch = OFF set failsafe_throttle_low_delay = 100 set failsafe_procedure = DROP set rx_min_usec = 885 set rx_max_usec = 2115 set acc_hardware = AUTO set acc_lpf_hz = 10 set accxy_deadband = 40 set accz_deadband = 40 set acc_unarmedcal = ON set acc_trim_pitch = 0 set acc_trim_roll = 0 set baro_tab_size = 21 set baro_noise_lpf = 0.600 set baro_cf_vel = 0.985 set baro_cf_alt = 0.965 set baro_hardware = NONE set mag_hardware = NONE set mag_declination = 0 set pid_process_denom = 4 set blackbox_rate_num = 1 set blackbox_rate_denom = 1 set blackbox_device = SDCARD set blackbox_on_motor_test = OFF set magzero_x = 0 set magzero_y = 0 set magzero_z = 0 set ledstrip_visual_beeper = OFF set sdcard_dma = OFF set osd_units = IMPERIAL set osd_rssi_alarm = 20 set osd_cap_alarm = 2200 set osd_time_alarm = 10 set osd_alt_alarm = 100 set osd_vbat_pos = 2433 set osd_rssi_pos = 2074 set osd_flytimer_pos = 2454 set osd_ontimer_pos = 374 set osd_flymode_pos = 2062 set osd_throttle_pos = 2177 set osd_vtx_channel_pos = 200 set osd_crosshairs = 2048 set osd_horizon_pos = 200 set osd_current_pos = 2447 set osd_mah_drawn_pos = 2441 set osd_craft_name_pos = 2081 set osd_gps_speed_pos = 66 set osd_gps_sats_pos = 386 set osd_altitude_pos = 161 set osd_pid_roll_pos = 322 set osd_pid_pitch_pos = 354 set osd_pid_yaw_pos = 386 set osd_power_pos = 47 set osd_pidrate_profile_pos = 418 set osd_battery_warning_pos = 200 set vcd_video_system = 2 set vcd_h_offset = 0 set vcd_v_offset = 0 set displayport_msp_col_adjust = 0 set displayport_msp_row_adjust = 0 set displayport_max7456_col_adjust = 0 set displayport_max7456_row_adjust = 0 profile 0 set pidsum_limit = 0.500 set pidsum_limit_yaw = 0.500 set d_lowpass_type = PT1 set d_lowpass = 111 set d_notch_hz = 260 set d_notch_cut = 160 set vbat_pid_gain = OFF set pid_at_min_throttle = ON set anti_gravity_thresh = 350 set anti_gravity_gain = 3.000 set setpoint_relax_ratio = 85 set d_setpoint_weight = 81 set yaw_accel_limit = 10.000 set accel_limit = 0.000 set iterm_windup = 50 set yaw_lowpass = 0 set p_pitch = 65 set i_pitch = 55 set d_pitch = 28 set p_roll = 55 set i_roll = 45 set d_roll = 20 set p_yaw = 90 set i_yaw = 40 set d_yaw = 55 set p_alt = 50 set i_alt = 0 set d_alt = 0 set p_level = 50 set i_level = 50 set d_level = 100 set p_vel = 55 set i_vel = 55 set d_vel = 75 set level_sensitivity = 55 set level_limit = 55 rateprofile 0 rateprofile 0 set rc_rate = 103 set rc_rate_yaw = 103 set rc_expo = 0 set rc_yaw_expo = 0 set thr_mid = 50 set thr_expo = 0 set roll_srate = 75 set pitch_srate = 75 set yaw_srate = 75 set tpa_rate = 10 set tpa_breakpoint = 1650 #
Quads: RealACC X6R ; RealACC X210 Pro, Omnifbus F3 FCs; RunCam Swift 2 & Swift 2 Rotor Riot, Emax OG Red Bottoms, Emax RS2205S 2300kv; Fatshark DOM V3 YouTube - Mr.E_fPv • Posts: 164 Threads: 36 Likes Received: 83 in 46 posts Likes Given: 124 Joined: May 2017 Reputation: 4 13-Jun-2017, 01:57 PM (This post was last modified: 13-Jun-2017, 02:47 PM by rryyyaann.) UPDATE: I've confirmed through an unsafe method, that the number 3 motor is cutting out during flight. I'll pop some good motors on and see if that's the issue or the esc. Guys I think it's a lost cause now. I reset EVERYTHING back to stock betaflight and now its tumbling out of the sky. It willl fly for a second then it just goes crazy. I'm thinking all this could be motor related. One motor sputters on start up and MIN throttle is 1070 its more than enough so I'm thinking that motor is cutting out mid air. I appreciate all your help but I dont think we need to waste our time anymore I'll get it figured out eventually. Good news is its my old quad I was just trying to keep in the air. Quads: RealACC X6R ; RealACC X210 Pro, Omnifbus F3 FCs; RunCam Swift 2 & Swift 2 Rotor Riot, Emax OG Red Bottoms, Emax RS2205S 2300kv; Fatshark DOM V3 YouTube - Mr.E_fPv • Posts: 2,410 Threads: 136 Likes Received: 1,790 in 1,052 posts Likes Given: 3,302 Joined: Jan 2017 Reputation: 50 13-Jun-2017, 03:36 PM (This post was last modified: 13-Jun-2017, 03:48 PM by Drone0fPrey.) I see min_throttle set @ 1020 in the dump you shared. But that does sound like a motor or ESC problem or even maybe ESCs need calibrating or solder joints checked. Just some brainstorming I hate it when a quad isn't flying Hope you get it figured out, who ever said an old quad can't learn new tricks |
