Low Cost, High Resolution FPV Camera Setup
Hello,
I am currently working on a university research proposal that will use cameras to detect open parking spaces. I don't have any prior experience with FPV cameras, but I felt that they would work well in this context given that they can stream video over long ranges and require small amounts of power to function. Seeing as the available parking spaces only need to be detected once every few seconds, latency and FPS are not important. In fact, sending a still frame every 10 seconds would be sufficient. What is important however is the resolution of the image being sent. High-resolution images are optimal for the image processing algorithm used to detect available cars.
So ideally the FPV camera and transmitter would be low cost, sacrificing FPS and latency in order to send a high-resolution image over long distances (1km). Power consumption is also an important factor with the hope that the camera might be able to run off a solar battery pack similar to this one:
https://www.amazon.com/Portable-Charger-...ar+charger
I have no idea whether this is feasible, so I greatly appreciate any suggestions and or alternatives.
FPV camera and transmitter are not high resolution. Think more standard definition TV and not 1080P. The video you see on TV are recorded with a GoPro.
High definition is possible with FPV, but you a special setup which is bulky and expensive. 1 km transmission might be possible. But I see other problem with using FPV equipment. The heat the transmitter will generate.
This one is the closest I've seen:
https://oscarliang.com/fpvmodel-hd-fpv-system/
I wish someone would make a hi def fpv cam....cuz the current lot for the most part suck.
It would be so nice to get higher definition. 480p, which is DVD quality would be great.
  • Krohsis
  New Product SpeedyBee 5.8GHz FPV Goggles Receiver Module (Analog) SnowLeopardFPV 2 1,399 14-Feb-2024, 03:24 PM
  Camera Plug Wiring segler999 5 430 30-Dec-2023, 05:17 PM
Last Post: segler999
  Camera and VTX connection best practice? husafreak 9 731 24-Dec-2023, 10:11 PM
Last Post: husafreak
  Help FPV goggles antenna boooood 2 749 04-Dec-2023, 05:38 AM
Last Post: Rob3ddd
  Best hd camera for 5 inch freestyle drone? PJKMBAKER 3 644 30-Sep-2023, 12:05 PM
