Looking for prop information
I have a 250 quad with 2204 2300KV kensaw motors, I believe can't remember the exact brand, with dys 20a esc. Xm20 model and I use 3s batteries. I have gf 5030 props and I want to try these Dal props and some tri blades. Are there any websites I can figure out my current draw? Or does anyone know if I can use triblade or 5045 props? Id like to learn more about the difference in 5030 and 5045. Not new to rc, but new to flying things.
Thanks in advance.
Here is the thrust data for those motors.
http://rotorgeeks.com/index.php?route=pr...uct_id=396
It looks like 5045bn props are pulling 24 amps. That's pushing it to the edge with your esc's, but I personally would run them. What I've heard about these bench tests is they will show more current draw than you will actually see in the air. 5x4x3 is probably the max tried blade you would want to use.
Edit: just saw you are using 3s. In that case you will have no issues. Probably want to look into 6" props if you want max thrust.
I may look in to that. Thing is still really fast for me so I doubt I would upgrade to 4s anytime soon. Still flying in horizon since I don't have the balls for acro lol
  Solved Prop noise when releasing throttle skamtastik 6 320 28-Jul-2023, 12:43 AM
Last Post: skamtastik
  Prop Colours Bad Raven 11 383 02-Jul-2023, 04:04 AM
  Discussion When is a prop too damaged? Lemonyleprosy 21 2,055 01-Jul-2023, 07:39 PM
  Longer prop vs higher pitch opossum.fpv 2 352 28-Apr-2022, 03:57 AM
  Help for motor/prop choice for a 4" @ 249g? neex 6 647 20-Jan-2021, 10:54 PM
Last Post: neex
