30-Sep-2016, 08:50 AM
Long awaited FC is almost here guys. It has what we all requested so someone out there heard us and is giving it to us
http://www.banggood.com/Eachine-FRF3_EVO...91779.html
First of all the dimensions are very close to a SciSky (Quanum Pico) and same as previous ones Fc's that are currently in BG from Eachine.
Build in Frsky Rx SBUS ACCST protocol.
Build in telemetry on VBAT (finally)!
A buzzer port.
LED port.
You will need to setup your Taranis model with D8 mode X9D for the channels. I don't know if they meant PPM protocol as all PPM Rx's in FrSky is usually in D8 mode.
Features
A buzzer port.
LED port.
Features
- Size: 33mm x 20mm x 4mm
- Weight: 2g
- CPU: STM32F303 72Mhz
- Gyro + Accelerometer: MPU6500
- Working Voltage: 3.7v Range (3.3v - 4.2v)
- Receiver: FRSKY 8CH SBUS protocol
- Compatible Tx: FrSky X9D/X9D PLUS (D8 Mode) XJT, DJT, DFT, DHT
- Channel Map: TAER1234
- Default Unlock Channel: AUX1 (Channel 5)
