I have seen a lot of ppl talking about both of these ESCs, but couldn't find any comparison between them.
The thing is, I recently got an Eachine 250 racer aaaand MIGHT have burned one or two ESCs with a bad motor provided by Banggood (still gonna try to get new ones, this quad definetly isn't a 4s setup)
(BTW motors jamming, rarely spinning and ESC burning hot is a motor issue, right?)
Anyways, even though I must change motors I feel like those ESCs are not realiable and want to upgrade asap.
Which one of these two would you advise? (or another one)
-LittleBee 20A ESC BLHeli OPTO 2-4s Oneshot125 support
-DYS BL20A mini ESC OPTO 2-4s (not sure if it supports oneshot125 but I guess so)
*I've read that these DYS mini usually get on fire (or it was just a huge batch of bad ones)
It also seems to me that both of them already come with the BLHeli firmware, no need for flashing (unless I want the newest firm - which is not really necessary for now I guess).
thanks in advance!
Edit: video showing the issue going on -
Fail attempt after motor worked for 2min. after that never more:
thanks in advance!
