I'm having some trouble tuning my Lisam LS210 with Beerotor F3 (BF2.8.1), Littlebee 20A (BLheli 14.6) and 2205 Kingkong motors (I changed out my 2204 Sunnysky with the kingkong 2205 since I tought they were causing vibrations). I get a lot of vibrations during mid throttle flying. I have tried lowering the P and D, but then it is not flying good at all. I'm flying Betaflight 2.8.1 with stock PIDs except I on pitch. For me, it looks like the D is too high on both roll and pitch when looking at the blackbox log, but I have tried lowering the D to 5, but it is still P-term Oscillations. When lowering P, the quad feels sluggish. I feel I'm missing out something here.
I thought at first it was vibrations from the motors, since the vibrations have gotten worse, so I changed them. I also noticed that one of the ESCs where damaged, so this was also changed, but the vibrations are still there.
It was flying good on stock PIDs on earlier Betaflight releases. I only had to increase I-gain on pitch.
Blackbox log:
https://www.dropbox.com/s/wbkvkqb6vhxb6h...1.TXT?dl=0
Blackbox log:
Entering CLI Mode, type 'exit' to return, or 'help'
# dump
# BetaFlight/SPRACINGF3 2.8.1 Jun 19 2016 / 20:31:49 (0c5ea0f)
# dump master
# mixer
mixer CUSTOM
mmix 0 1.000 -1.000 0.771 -1.000
mmix 1 1.000 -1.000 -0.771 1.000
mmix 2 1.000 1.000 0.771 1.000
mmix 3 1.000 1.000 -0.771 -1.000
smix reset
feature -VBAT
feature -FAILSAFE
feature -SONAR
feature -CURRENT_METER
feature -ONESHOT125
feature -BLACKBOX
feature -TRANSPONDER
feature -AIRMODE
feature -SUPEREXPO_RATES
feature VBAT
feature RX_SERIAL
feature FAILSAFE
feature CURRENT_METER
feature LED_STRIP
feature ONESHOT125
feature BLACKBOX
feature AIRMODE
feature SUPEREXPO_RATES
# beeper
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
# map
map AETR1234
led 0 15,15:ES:IA:0
led 1 15,8:E:WF:0
led 2 15,7:E:WF:0
led 3 15,0:NE:IA:0
led 4 8,0:N:F:0
led 5 7,0:N:F:0
led 6 0,0:NW:IA:0
led 7 0,7:W:WF:0
led 8 0,8:W:WF:0
led 9 0,15:SW:IA:0
led 10 7,15:S:WF:0
led 11 8,15:S:WF:0
led 12 7,7:U:WF:0
led 13 8,7:U:WF:0
led 14 7,8:D:WF:0
led 15 8,8:D:WF:0
led 16 8,9::R:3
led 17 9,10::R:3
led 18 10,11::R:3
led 19 10,12::R:3
led 20 9,13::R:3
led 21 8,14::R:3
led 22 7,14::R:3
led 23 6,13::R:3
led 24 5,12::R:3
led 25 5,11::R:3
led 26 6,10::R:3
led 27 7,9::R:3
led 28 0,0:::0
led 29 0,0:::0
led 30 0,0:::0
led 31 0,0:::0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
aux 0 0 0 1550 2100
aux 1 12 0 1100 1500
aux 2 14 0 1750 2100
aux 3 25 1 1875 2100
aux 4 0 0 900 900
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
# adjrange
adjrange 0 0 0 900 900 0 0
adjrange 1 0 0 900 900 0 0
adjrange 2 0 0 900 900 0 0
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0
adjrange 12 0 0 900 900 0 0
adjrange 13 0 0 900 900 0 0
adjrange 14 0 0 900 900 0 0
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# servo
set min_check = 1100
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 30
set rssi_ppm_invert = OFF
set max_aux_channels = 6
set debug_mode = NONE
set min_throttle = 1020
set max_throttle = 2000
set anti_desync_power_step = 0
set servo_center_pulse = 1500
set unsynced_fast_pwm = OFF
set fast_pwm_protocol = ONESHOT125
set motor_pwm_rate = 400
set servo_pwm_rate = 50
set disarm_kill_switch = ON
set small_angle = 25
set fixedwing_althold_dir = 1
set gps_provider = NMEA
set gps_sbas_mode = AUTO
set gps_auto_config = ON
set gps_auto_baud = OFF
set gps_wp_radius = 200
set nav_controls_heading = ON
set nav_speed_min = 100
set nav_speed_max = 300
set nav_slew_rate = 30
set serialrx_provider = IBUS
set sbus_inversion = ON
set spektrum_sat_bind = 0
set telemetry_switch = OFF
set telemetry_inversion = ON
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set battery_capacity = 0
set vbat_scale = 208
set vbat_hysteresis = 1
set current_meter_scale = 380
set current_meter_offset = 0
set current_meter_type = ADC
set align_gyro = DEFAULT
set align_acc = DEFAULT
set align_mag = DEFAULT
set align_board_yaw = 0
set gyro_lpf = OFF
set gyro_sync_denom = 4
set gyro_lowpass = 100
set moron_threshold = 32
set alt_hold_deadband = 40
set alt_hold_fast_change = ON
set deadband = 0
set yaw_deadband = 0
set yaw_control_direction = 1
set yaw_motor_direction = 1
set tri_unarmed_servo = ON
set servo_lowpass_freq = 400
set airmode_activate_throttle = 1350
set failsafe_delay = 10
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_procedure = OFF
set gimbal_mode = NORMAL
set acc_hardware = AUTO
set acc_lpf_hz = 10.000
set accxy_deadband = 40
set accz_deadband = 40
set acc_unarmedcal = ON
set acc_trim_roll = 0
set baro_tab_size = 21
set baro_noise_lpf = 0.600
set baro_cf_vel = 0.985
set baro_cf_alt = 0.965
set baro_hardware = AUTO
set mag_hardware = AUTO
set mag_declination = 0
set pid_process_denom = 1
set blackbox_rate_num = 1
set blackbox_rate_denom = 2
set magzero_x = 0
set magzero_y = 0
set magzero_z = 0
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 8 h
rxfail 9 h
# profile
############################# PROFILE VALUES ####################################
set gps_pos_p = 15
set gps_pos_i = 0
set gps_pos_d = 0
set gps_posr_p = 34
set gps_posr_i = 14
set gps_posr_d = 53
set gps_nav_p = 25
set gps_nav_i = 33
set gps_nav_d = 83
set yaw_p_limit = 500
set dterm_lowpass = 100
set dynamic_iterm = ON
set iterm_ignore_threshold = 200
set yaw_iterm_ignore_threshold = 35
set yaw_lowpass = 80
set pid_controller = LUX
set p_pitch = 50
set i_pitch = 45
set d_pitch = 18
set p_roll = 45
set i_roll = 40
set d_roll = 18
set p_yaw = 90
set i_yaw = 45
set d_yaw = 20
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 50
set i_level = 50
set d_level = 100
set p_vel = 55
set i_vel = 55
set d_vel = 75
# rateprofile
set rc_rate = 100
set rc_rate_yaw = 100
set rc_expo = 10
set rc_yaw_expo = 10
set thr_mid = 50
set thr_expo = 0
set roll_rate = 70
set pitch_rate = 70
set yaw_rate = 70
set tpa_rate = 20
set tpa_breakpoint = 1650
