Lipo placement
Hello Guys,
Do someone have some good tips and tricks to place the lipo every time on the same place on a brushed quad.
I have a QX95 but it's hard to place the lipo on the same place so the COG is not changing to much.
After i have changed the lipo i need to trim the quad so it stays on the same spot and that cost some flight time.
You could use this kind of velcro: https://www.amazon.com/Reclosable-Fasten...+dual+lock
It's super strong - and when it's connects, it clicks vs. just mashing normal velcro together.
With this - you could probably use a smaller piece and hit the center more easily? Or... honestly - just ditch the velcro and use a rubber band so you shift it around easily until you find the right spot. That's what I do with my brushed quads. Just put the battery through the rubber band - pinch the quad between my fingers where I think the CG is and see how it feels.
The other thing that I've found is that some receivers can drift a bit (especially the micro ones) ... seemingly randomly (weather, temp, voltage, who knows ...) and this is inevitable. So the trimming may be related to that drift.
Lastly, hitting the CG is important, but if you switch over to rate/acro mode (which is a big jump, I know) you don't have to deal with trimming nearly as much.
Maybe these would work.
http://intofpv.com/t-batterytabs-velcro-tm-replacement
(The females are also available to print at the thingiverse link.)
Mark the outline, or end of the optimal lipo position somehow on the frame?
That is, if all your lipos are about same weight and size.
Yes velcro does the trick for me. I dont even need rubber bands for it
Thanks for the tips guys, i already placed 3 stand off's to place the lipo everytime the same time as possible.
I also fly LOS i'm not yet in the FPV, i need first a screen for that. And i fly in acro mode.
And i like it when i give some throttle only that the quad moves up, and yes i know that the possibillity for some drift will be always there, but i'm also a perfectionist.
[Image: zJgwYZAl.jpg]
  BT2.0 connector on 2S Lipo Pathfinder075 26 1,533 03-May-2023, 09:36 PM
  Tip & Trick Lipo's support for Tinyhawk 2 freestyle Krayon70 7 1,200 25-Jul-2021, 02:47 AM
  Help Mobula7 crazy LiPo tension variations Ahaw 5 1,015 21-Feb-2021, 10:36 AM
Last Post: Ahaw
  Help Help Betafpv f4 12a aio lipo only red led, lipo and USB everything works TwistedFPV 2 685 01-Feb-2021, 08:16 PM
Last Post: TwistedFPV
  Tutorial Make a 1S LiPo Batteries charging cable Oscar 19 32,202 18-Oct-2020, 09:49 PM
Last Post: brettbrandon
