LED not working in Betaflight
Cant get WS2812 Leds working on Betaflight. I tried many versions already, 2.8 and 2.6
As always, i did this:
- RX_Serial -> SBUS -> Port enable Serial RX....also tried RX_PPM -> SPEKTRUM1024
- enable LED_Strip
LED Tab:
wire 0-7 -> pic color -> save
On the latest Cleanflight i works.
LEDs are connected to CH5
I also tried betaflight release 2.5.4 and 2.5.3. also dont work
On one of my other quads i have 2.5.3 on a flip32 and it works with the same settings. So there must be something wrong with the naze32 rev 6
First of all LED won't work properly if your looptime is too low, i think 1000 is the bare minimum.
Have you had a read of Oscars great blog on this subject?
https://oscarliang.com/setup-rgb-led-cleanflight/
My youtube channel
  • T18099
  Betaflight Github questions Rob Axel 6 196 13-Feb-2024, 11:40 AM
  betaflight config 10.10 RC2 issue Rob Axel 3 227 10-Feb-2024, 01:21 PM
  Betaflight Motor Test Results in SmokeStopper overvoltage LoganFPV 5 233 01-Aug-2023, 11:22 AM
  LED Strips (diffused) the.ronin 2 331 04-Aug-2022, 01:02 AM
Last Post: Lemonyleprosy
  Build T-Motor F7 stack - Betaflight Gyro update frequency 3.2kHz ???? MindBenderFPV 2 3,081 18-Jun-2022, 09:10 AM
