LED/DShot Simultaneous Use On Radiance FC
I'm not sure if this is the same for all FCs when running DShot but on the Radiance I cannot use an assignable LED strip while running DShot.
Is this common among all boards or just on the Radiance? Is there a workaround like using CLI to reassign the channel to a different port or ?
There are quite a few flight controllers that can't use programmable LEDs while using DShot. This is down to the fact that the LEDs must be updated at a high rate, just like the DShot signal and the MCU's DMA controller is used for this to ease the load.
As there are a limited number of DMA channels available, and there are restrictions as to what pins a DMA channel can be assigned to, many flight controllers just can't do everything at once.
Unless you absolutely must have DShot, switching to Multishot will give you your LEDs back and still allow you to run very fast loop times. I don't believe there is a way to use LEDs and DShot at the same time on this board, but then again, I don't have one myself.
  • Khutchinson22
(15-Apr-2017, 12:13 PM)unseen Wrote: There are quite a few flight controllers that can't use programmable LEDs while using DShot. This is down to the fact that the LEDs must be updated at a high rate, just like the DShot signal and the MCU's DMA controller is used for this to ease the load.
I feel better knowing it's not just my equipment. I prefer to have better flight processing and sacrifice the lights, TBH.
Thanks for explaining that. Makes much more sense now.
Photo Help Mamba F405 Motor 3 not working when LED added Toppers 20 3,538 01-Nov-2023, 10:21 PM
Last Post: onesimos
  Crazybee4S1280 - LED showing error? BadRaven 4 234 25-Jul-2023, 08:54 PM
Last Post: V-22
  Betaflight LED problem NickyWicker 3 530 01-Apr-2023, 01:49 AM
Last Post: NickyWicker
  Help How to fix LED strip? romangpro 1 211 19-Mar-2023, 12:59 PM
Last Post: Lemonyleprosy
  Help Is continuity on the LED pad normal? theon_Jules 4 346 27-Dec-2022, 12:44 PM
Last Post: theon_Jules
