Threads: 30
Likes Received: 1,199 in 755 posts
Likes Given: 714
45 Look on the back, you have 4 pads. + (red) & - (black) are connected to 5 volt power supply on your pdb. Buzzer goes to buzzer pad on your flight controller. It will work just fine like this, but you also have the option of connecting the DIN pad to the LED pad on your flight controller for more advanced light shows
Threads: 38
Likes Given: 1,881
72 The buzzer pad is marked "-", so you should connect the BUZ- pad on the X-Racer to the buzzer pad on the board. The 5V to the board will provide the + connection to the buzzer.
Threads: 26
Likes Received: 37 in 25 posts
Likes Given: 68
2 Ok it was what i wanted to be sure because the printing on buzzer pdb is not perfectly readable. It is just a small dot instead a ground sign.
So the "signal" wire from fc is the negative!
Thank you vera much! !!
Threads: 26
Likes Given: 68
2 Thanks for the great explanation!
I will solder the 5v positive and negative coming from the pdb bec, din from fc and negative from buzzer pin on fc to buzzer pad.
Hope it will works.
Thanks again
