Large black stripe on DVR footage bottom
Any idea why FatShark Dom V2 records DVR footage with a little strap on the bottom as if it was from another frame and it is stuck there? It is not always like that.
different resolution of PAL and NTSC? try to power on the quad first then the goggle and try again? Goggles normally detects what the format sent from the camera/VTX at power up
If I turn on the quad before I turn on my doms I get this line at the bottom. The DVR doesn't know if it's supposed to be in pal or NTSC. This is usually caused by pal cam recording in NTSC mode, the DVR doesn't know what to do with the extra lines so it's puts it at the bottom.
There's an upgraded DVR from fatshark that fixes this if you feel the need.
[-] The following 1 user Likes Multirotor Army's post:
  • Trollhammered
  Black Friday scores? Lemonyleprosy 10 585 07-Dec-2021, 12:57 PM
Last Post: kafie1980
  Discussion Using GoPro Hero 7 Black as an FPV camera manjulaltn 15 12,344 29-Aug-2019, 05:17 AM
Last Post: manjulaltn
  Discussion Eachine ROTG01 vs ROTG02 vs DVR Review – FPV Receiver Range & Signal Tests. Bill M-RC 6 7,114 09-Jun-2019, 09:44 AM
Last Post: Maiden Flight
  Bottom batery mount suggestions Krohsis 15 1,468 30-Aug-2018, 01:50 PM
Last Post: sloscotty
  Help Video goes black after throttle! Savage FPV 25 7,454 30-Sep-2017, 12:12 PM
Last Post: unseen
