kombini doesn"t start up
hi, I'm new to the hobby of building quads so please be gentle.
I used a kombini fc and checked all my connections with a multimeter. no shorts! yet when I plug in the usb it showes no green light or any sign of connecting to the computer (betaflight). is it me or the kombini?
please help
Claus
Check with another USB cable. If you are still not even getting any light, then likely your FC was DOA.
(27-Sep-2017, 12:48 AM)voodoo614 Wrote: Check with another USB cable. If you are still not even getting any light, then likely your FC was DOA.
Thank you for your reply. You are voicing what i thought.
It sounds like you've already soldered your Kombini. Sadly, this will make it hard to get a replacement.
The first thing I do when I receive a new flight controller is plug in the USB connection and make sure I can connect to it with the configurator and see that the gyro works. If there's a problem, getting a replacement is not an issue.
(27-Sep-2017, 07:20 AM)unseen Wrote: It sounds like you've already soldered your Kombini. Sadly, this will make it hard to get a replacement.
While I've had my share of problems getting support in this hobby... I would think that soldering the board would be a bad excuse for not providing warranty services considering that this product is designed to be soldered to other components. That is assuming that there even was any expressed warranty.
I'd still try to see if whomever you bought it from would let you return it! I hear that banggood can be OK with returns if you provide pictures and or videos... and I know that amazon typically is pretty good with returns as well.
carl.vegas
Quite a few sites say "If you solder it, you've bought it". Depending on the fault, poor soldering can be the cause, so to an extent, I understand why some say this.
Sounds a lot like PC companies saying that opening a case voided the warrantee in the 90s. It's a way to cop out of quality defects.
carl.vegas
(27-Sep-2017, 03:58 PM)Carl.Vegas Wrote: Sounds a lot like PC companies saying that opening a case voided the warrantee in the 90s. It's a way to cop out of quality defects.
I bought a PC 4 years ago advertised with a 450W PSU, opened it after a year to upgrade the GPU (voiding my 2 year warranty) and found that it had a 250W PSU not the 450W that was advertised. The model number of the PSU was something...450W, but the spec sheet said nothing about 'peak output' only 250W. The retailer replaced it with a 450W and said that, in future they would be more stringent with checking what their suppliers actually provide.
I did. Lesson learned. I sent a message to atmospheric adventures and will see. BTW they have the best prices.
I have not had too much trouble with any of the vendors I buy from. I bought an Omnibus F3 AIO. Everything flashed. it worked when connected to the computer. When I tried to calibrate the ESCs (what is ESC calibration? that is so yesterday), the motor would spin under USB power. In my case, there is no way you can figure out that the FC was defective without soldering. I have to give credit to most of the vendors are pretty good about returns or replacement.
I also wonder the percentage of defects is user errors.
(27-Sep-2017, 05:43 PM)voodoo614 Wrote: I also wonder the percentage of defects is user errors.
Not to turn this into too much of a rant about defects (too late... although maybe I can get away with it because I work in QA in my professional life?)
Damage to a product is not necessarily a "defect" per se, unless that damage was caused by a failure of the product to work as designed / advertised. If it's user error it's usually just "damaged goods". Of course companies have to watch out for damaged goods being returned as defective products.
In a case like the one that the OP has it's unlikely that wiring up the quad is going to blow just the USB connection... which actually brings me to a question to help troubleshoot:
What happens when you power up the quad with a LiPo?
If it powers up with a LiPo, and the motors play the ESC tones... then that's very likely a defect @ the USB connector... To use action taken on a product as an excuse not to make defects right is just lazy customer service and shouldn't be accepted by consumers unless they decide that the effort put into resolving the issue isn't worth the return, or unless the manufacturer clearly states that the product is sold as-is (which is rare for new products).
carl.vegas
I think most vendors are pretty good, especially if you have some history with them and they can see that you're not a chancer.
Still, having seen some of the soldering nightmares that you can find on various forums, there's certainly an element of truth in saying that some hardware failures are caused by incompetent soldering and it's hardly fair to expect the vendor to take the cost of replacement when the user caused the problem.
If a vendor does so as a matter of course, the costs tend to get passed on to their customers. As someone who can solder and who inspects everything very carefully before applying power, I don't see why I should pay to subsidise the customers who obviously have no idea what they are doing.
  • Carl.Vegas
  Where do I start PID tuning this quad? relentlesstech 15 228 17-Mar-2024, 05:22 PM
  Help, my OSD doesn't jive with the elements in the BF preview (DJI) paddle2thesea 2 106 01-Mar-2024, 12:53 AM
Last Post: paddle2thesea
  Servo doesn't wokr on Speedybee F405 V4 A55 serhios 1 412 18-Jan-2024, 09:43 PM
  Drone doesn#t arm janpme 1 197 06-Dec-2023, 04:32 AM
  AOS 3.5 doesn't fit GEPRC GR1404 Motor ? niuk 2 148 03-Oct-2023, 09:06 PM
Last Post: niuk
