KISS FC - ESC reset during flight
I bought one of the first release Kiss FCs a while ago, it worked for a few flights then output 4 stopped working all together. In goes a replacement, all set up and hovers fine, it'll hover in one spot for an entire battery.....
However as soon as I start to roll hard left or right, ESC 2's output resets itself, causing the quad to death spiral. They are Littlebee 20A, it doesn't do a power reset, only the signal part of the start up tone sounds when this happens. Have I got myself another dud Kiss FC? I really couldn't be boned swapping it out and testing with a known, working board if it's a common issue.
I am using 1.02, Beta74 version firmware.
there is newer version available beta RC16, Try it may help
I have also seen people experiencing similar with little bees in the RCG thread, many have said raising min throttle corrected it. How far above idle is yours set? If 10 or less, try bringing it up to say, 20, and see if it still does it.
(04-Apr-2016, 08:17 PM)MacFly90 Wrote: there is newer version available beta RC16, Try it may help
I currently have min throttle set to default (1070 I think)with an idle up switch, 1050 on min command. Perhaps I'll try moving both those values up by 20 and see if it goes away.
Anybody have solution to this? Or figure out the problem? I'm wondering if it could be associated with tuning? I'm having random drop outs where quad just falls and spins like crazy. Didn't start till my tuning got more aggressive. Going to try adjusting. Moved min throttle up well above idle around 1085 no dice. Flies so nice though.
  Flywoo AIO BF4.4.3 ESC question husafreak 4 159 03-Feb-2024, 03:32 AM
Last Post: husafreak
  Help FC wiring to different ESC brand cele_FPV 2 143 30-Jan-2024, 10:29 PM
Last Post: cele_FPV
  Help No response flight controller with receiver Crazyart 1 235 09-Jan-2024, 12:53 AM
Last Post: Crazyart
  BetaFPV F4 FR 2S flight controller issues. itsmerandy 30 1,660 02-Nov-2023, 09:01 AM
  FC to ESC wiring diagram Help oddjobsguy 4 900 01-Oct-2023, 03:30 AM
Last Post: oddjobsguy
