Kiss ESC flash in PDB
Hi,
got some version 1.0 KISS 24a ESC soldered in the the KISS PDB - now with Dshot available Im trying to get em updated but fail to do so. Tried to get the serial with my W10 box - no luck - with a Linux also no luck - not getting any signs of the ESC
Tried this FTDI:http://www.ebay.de/itm/FT232RL-FTDI232-U...0699598695
2 questions:
-is / would it generally possible to flash soldered in the PDB? (hard to get them desoldered)
-did someone used the FDTI above successful or should I get/try a different one?
Thanks in Advance
Clemens
1. yes, as long as your PDB isn't powered on, and whatever devices connected to TX/RX isn't powered on
2. yes that one looks like the one we get from BG should be okay.
  Help TMotor F55 Pro ii ESC won't power FC after crash EyeBotXander 2 271 11-Apr-2024, 09:32 PM
Last Post: EyeBotXander
  Solved ESC and FC rebooting during motortest zsolth 5 120 11-Apr-2024, 01:34 PM
Last Post: zsolth
  Solved Cannot connect ESC derange 2 150 22-Mar-2024, 10:05 PM
Last Post: derange
  Solved Cannot recognise 1 Esc at 4in 1 Esc Mad35 11 220 12-Mar-2024, 01:47 PM
  Help ESC working but motor not spinning Prashant1901 1 147 10-Mar-2024, 02:09 AM
