kiss 24a esc problem
As i mentioned in the speed addict thread i have made a BIG mistake and wired the ground signal wire to the TLM on my 24a esca and now they are lifeless. does anyone know of a fix for this or are they just toast now?
 waiting in anticipation[Image: sad.png]
I wouldn't have thought soldering the gnd signal wire to the TLM would have caused your ESC's to die. If it was going to be an issue one would have thought KISS would have made a note in the ESC manual.
Maybe a KISS expert can help here.
My youtube channel
Big Grin
(02-Jul-2016, 11:39 AM)BigglesFPV Wrote: I wouldn't have thought soldering the gnd signal wire to the TLM would have caused your ESC's to die.  If it was going to be an issue one would have thought KISS would have made a note in the ESC manual.
Yes with a little luck.
there was no smoke or fire just the blue light went out and went lifeless. Ive looked in the manual and forums and cant find anything regarding this problem yet it was such an easy thing to do. As with all other escs the solder pads are together but there again they dont have the telemetry capabilitys of these. That ground pad is soooo small tho and being nearly 50 my eyes arent getting any better[Image: biggrin.png]
I dont think anyone would be technical enough to answer this question apart from the guys at Flyduino, drop them a message and find out Smile
But the TLM is a output, shorting it to GND will probably cause some large current and burning something...
(02-Jul-2016, 12:46 PM)Oscar Wrote: I dont think anyone would be technical enough to answer this question apart from the guys at Flyduino, drop them a message and find out Smile
Thanks oscar.
I have mailed them about it but yet to receive an answer.
  I didnt see smoke or fire and ive had a watchmakers glasses on taking a very close look and there is no burn marks, anything melted or any visible damage at all.
 This could be an expensive mistake eh.  Confused
  Help TMotor F55 Pro ii ESC won't power FC after crash EyeBotXander 2 268 11-Apr-2024, 09:32 PM
Last Post: EyeBotXander
  Solved ESC and FC rebooting during motortest zsolth 5 119 11-Apr-2024, 01:34 PM
Last Post: zsolth
  Solved Cannot connect ESC derange 2 147 22-Mar-2024, 10:05 PM
Last Post: derange
  Solved Cannot recognise 1 Esc at 4in 1 Esc Mad35 11 217 12-Mar-2024, 01:47 PM
  Help ESC working but motor not spinning Prashant1901 1 146 10-Mar-2024, 02:09 AM
