Kingkong 110GT receiver help -SOLVED-
Was getting ready to have some fun.
Before that I wanted to lower the min_throttle value because when doing flips it did small loops on the default settings it came in.
Changed that down.. Didn't run. Slowly moved it up untill I was back at the original value and then see the receiver is just not connected somehow.
[Image: e2fe56e6bef8dcc7eacd8cd708b06591.png]
https://gyazo.com/e2fe56e6bef8dcc7eacd8cd708b06591
TL: DR Changed Min_Throttle value. Put it back to normal, receiver not working.
Connecting battery and turning on transmitter gives me this:
https://gyazo.com/ef7d2e2af999cda068546a42f61b3bef
I set it to all the different receiver types. back to SBUS like 10 times. Tried to flash firmware, that failed, but reset everything again. Kept trying different things, setting it back. Eventually I got a signal from the transmitter. No idea what the problem was. Put the same settings it has now in over 10 times, but somehow, now it works..
Huh
At least it's working again!
  • laziegoblin
Question What is the best antenna for goggles with ONE receiver (Ls800d)? samysh 16 511 14-Mar-2024, 07:11 PM
Last Post: brettbrandon
  Connecting IA10B receiver to SpeedyBee F4V4 Ladu 2 126 12-Mar-2024, 05:46 PM
Last Post: Ladu
Question Elrs receiver blinks green once? FeuerKai 5 190 09-Mar-2024, 10:05 PM
Last Post: FeuerKai
  No Valid receiver signal detected. AIRT1776 8 347 18-Jan-2024, 04:55 AM
  Solved Can't power-up and setup built-in ELRS receiver hammix 2 450 09-Jan-2024, 06:26 PM
Last Post: hammix
