27-Feb-2017, 04:21 PM
Hi everyone!
So I'm very new to this hobby but am loving it. I just built a new mini quad (Armattan Chameleon) with an Omnibus F4 Pro FC, Armattant PDB V3, FrSky XSR, and originally a TBS Unify Pro VTX.
After my first couple of flights my VTX would only give me video if I was pointing straight at it and within a couple feet. I thought I messed up the UFL connector so I had a spare unify pro I swapped for. Same issue happened. I ensured I powered it via a 5V pin as I had to bridge RAM to VCC for full 4S to camera as camera wouldn't produce an image (Omnibus was putting out 4.43V when bridging RAM to 5V so I had to use 4S.)
Because the unify pro only supports 5V I used a spare 5V on the board. The board is rated to supply 5V 3A.
After the second unify pro stopped working I swapped it out for my Aomway 200mW VTX. To use the Aomway I had to solder leads to the RAM pin to get full 4S as it needs at least 7V.
The Aomway worked for quite a while. I actually don't know if it died from a wreck or not where I noticed too late that the SMA male tip broke off. Maybe it over heated without that small piece, but it stopped transmitting altogether. I tried a new antenna on it and confirmed it is done.
The one thing that concerns me, and why I came here to you all and tell this to ...is maybe it's back current from active braking from the ESCs? I was running it pretty hard to see how it performed. I did some 5-10 second punch outs. In blackbox I notice during those punch outs that it couldn't record anything (just missing data for those blocks.)
Any thoughts? How do I keep from eating up VTXs? (I'm also worried that maybe the Omnibus BEC cannot handle the active braking ...and I have Lipo positive lead going into Omnibus FIRST in order to use the FC's onboard current sensor.)
Thanks in advance!
Thanks in advance!
