Threads: 23
Likes Received: 8 in 8 posts
Likes Given: 3
0 Guys I have Bardwells Board from Race Day quads. I can see the camera but the issue is that I used the white wire in the harness for the osd and soldered it to the cam c pin on the board and I can not get the camera settings to come up in the goggles. I tried left stick and pitch up and also mid throttle and yaw right. Is there another stick combination I need to do or would there be something in betaflight I need to setup yet?
Threads: 125
Likes Received: 3,738 in 2,835 posts
Likes Given: 99
388 What camera are you using? Do you know what button if you have the OSD controller plug in to get into the camera menu. Every camera is a little different.
Threads: 23
Likes Given: 3
0 I'm using the foxeer preditor. No I don't know what button to use.
Threads: 23
Likes Given: 3
0 I already clipped the ground wire for the controller. Could I reorder another one?
Threads: 125
Likes Given: 99
388 09-Feb-2018, 02:28 AM (This post was last modified: 09-Feb-2018, 03:24 AM by voodoo614.) Search for "JST 2 pins 1.25 mm". If you want a replacement cable.
Threads: 30
Likes Received: 1,199 in 755 posts
Likes Given: 714
45 See page 6 of the JB manual for camera connections
