JB's Motor and Prop Data Spreadsheet / Video
JB publicised this on his live stream yesterday. The link below it to a Goggle spreadsheet he's put together that contains a whole load of pre-built (BNF/PNP) quads that shows proven motor size / Kv / LiPo combinations which are commonly used for various sizes of quads. This data is really useful when you are building your own quad because if you are struggling to work out what spec motors you need, this gives you a really good starting point on which ones to start looking at. Just filter by the various columns to narrow down the selection you are interested in.
Of course, you can also just go on Rotorbuilds, but you don't always know if the motors used on those builds ended up as a success or a failure.
This is a work-in-progress spreadsheet that will continue to grow as time goes on. There's currently a very limited selection of quads over 5" (only 4) but more will eventually get added as they appear on the market.
The one additional useful thing that is missing is the ratings of the ESCs used on these BNF/PNP quads. JB said he might consider going back and adding that info for reference, but it's not there yet.
https://docs.google.com/spreadsheets/d/1xpjDN-GJIaSJ_yyTewleAqNTGeFBCXdAb6RDpASf1Ks
[-] The following 4 users Like SnowLeopardFPV's post:
  • Krohsis, sloscotty, voodoo614, hugnosed_bat
JB has just released the following video to go with the spreadsheet I linked to in the first post...
  Discussion High kv motor + motor limit ≠ Low kv motor mstc 0 10 46 minutes ago
Last Post: mstc
  Solved 35mm Bi-Blade Prop 1mm Shaft brettbrandon 10 287 17-May-2024, 03:12 AM
Last Post: brettbrandon
Question Help Diatone MXC Taycon Cinewhoop's 4th motor isn't working rr240 2 190 28-Apr-2024, 02:58 PM
Question Help Diatone MXC Taycon Cinewhoop's 4th motor isn't working rr240 0 117 23-Apr-2024, 09:36 PM
Last Post: rr240
  Sometimes a motor surprises you - in a good way mstc 20 938 10-Apr-2024, 09:00 PM
Last Post: mstc
