19-Mar-2016, 07:55 PM
Progress on my first build. Not so sure I like some of the cabling and I may change that a bit, but I am further along then I was: )
IT"S ALIVE........well...sort of.... |
19-Mar-2016, 07:55 PM Progress on my first build. Not so sure I like some of the cabling and I may change that a bit, but I am further along then I was: ) "Damn the torpedoes!!! Full speed ahead!!!" 19-Mar-2016, 09:07 PM Moving along nicely! Is there a reason you didn't use 90 degree pins instead of going straight up with them? Better to go horizontal (if you can) than vertical. I know on my Fury 252 RX I had to end up soldering because my frame wasn't "tall" enough. Hopefully you don't have that issue. I am a developing Racer - getting better..... BNF Quads: <250 Eachine>; <250 Walkera Advanced CC3D>; <250 Vortex Pro> Built: Dronz Fury 252 RX ; Speed Addict 210-R Building: <Deciding on Third build - Suggestions?> 19-Mar-2016, 10:13 PM I thought about the 90 degree pins and on the osd board I did use them for exactly the reason you said - clearance. However on the FC, I have the clearance even wit the top cap on and using 90 degree pens it would have forced the wires toward the edge of the quad, possibly exposing them to damage during a crash (of which I am sure I will have many) : ) "Damn the torpedoes!!! Full speed ahead!!!" |
A 4" build that never flew (The Ronin mk2 is alive!) | drumgod | 20 | 933 | 12-Dec-2023, 06:34 PM Last Post: drumgod |
