This is how you start an argument with someone in the hobby, ask them: Is PPM Analogue or Digital Signal?
I posted this question on my Facebook group, and there was many different views on this. Here is a summary of the responses.
It's Digital!
Levi W:
Its Pulse Position Modulation, So its a standard logic pulse(3.3 or 5v), the data is just defined by the position of the pulse in reference to the clock cycle. Similar to PWM. Analog is where a signal varys in voltage, Digital only has two states, on and off, Generally 0v and 3.3 or 5v
Adriano D:
Digital, 0 and 1 levels only! It is generated digitally... But, as a "protocol" can be decoded both, digital or analogic way... Omho
Although is time dependent, it uses a "fixed time frame" to code/decode, larger pulses are multiple from this timeframe, so the double time can be interpreted as two high pulses and so on...This is a kind of protocol... But the signal amplitude does not carry any info...is pure digital, also you need a digital decoder or a DAC to use the info transmitted, so its a digital thing...
Basically, circuits operating on a saturation and cut levels (two levels only) are Digital.
I thing the fact that we can use a simple passive circuit as DAC, makes the confusion...
Martijn DK:
PPM is not a continuous transmission signal, but transmitted in a 27ms pulse interval, so i'd say its digital.
Sindre J:
PPM is digital. The signaling is either 0 or 1. (We all know this). I would state that the PROTOCOL is what makes it convey analog values. Ie. the protocol is time-based, where as SBUS uses fixed time base and serial protocol to convey analog values. Both are digital as they can only transmit ones and zeroes, but they have different protocols.
Norbert T:
SBUS and PPM are both digital but ppm is less efficient, because the information is based on how long the signal is on or off, while sbus is transferring the actual number in digital format that given channel has, also has error correction built into the protocol.
John L.:
Digital of course. Because it contains encoded bits.
Ole L.:
It's a digital encoded protocol where you measure digital steps based on a timer. The digital resolution is based on the timer frequency. Nothing analog here !
Forrest A:
PWM is technically a digital encoding, sort of. It was originally created to mimic analog signals, but it is indeed a digital signal. It just only encodes a single value. PPM is a way of conveying multiple PWM signals. It is also digital. It's a bit laggy though
It's Analogue Signal!
David Winstall Podcase (shared by Jack N):
around The 1:11:00 mark best explanation I've had!
Benedikt S:
PPM in this configuration is a series of PWM -analogue spaced pulses in a sequence... so the only digital component in the signal is the synchronisation "bit" that indicates the start of the serial data - but the actual width of the pulses is pure analogue right ?
question is - is the position of the servo encoded in a digital code or not when it goes out as a ppm signal, my answer is not - it's decoded by measuring the time of the pulse - the FC does that and converts it back to a number. time is analogue
if you think about it - this method is way older than the digital radios - this is from the 27Mhz AM time when we had very simple radios with no TTL chips, the pulse width was just made with a oscillator from the position of the gimbals with normal potentiometers - think we still use old pot's - no optical encoders yet?
Rick V:
Digital is not ever-present, relies on a clock or timing signal and does not vary its strength.
Bob R.
The signal of each channel is determined by the width of that channels pulse. All channels are sent together in a compressed pulse. At least that's how I understand it. There is some delay depending on the pulse width which I think is about 27ms for 8 channels. Cleanflight based FC's usually average three pulse before responding so the delay is 27x3. Serial links don't have this dilemma. Also from this link: "A pulse Width Modulation (PWM) Signal is a method for generating an analog signal using a digital source."
Andrew M:
Just because it uses high and low wave patterns doesn't make it digital smile emoticon Digital would be if it read 1 and 0 and turned that back into something. It uses the width which is varying length so instead of a wave form going up and down the length of the on pulse gets longer and shorter. That is where the analog comes in.
It's Both!
Eric Andreas S
PPM use the means of analog transfer from point A to point B (as all do) where the signal is either 0 (voltage < 1V. Note: Going down to 0V is pretty much impossible due to the heat it would generate) or 1 (voltage > 3,3/5V depending on hardware). This is similar to the way a CPU works where the voltage is an "analog" curve but the interpretation of this curve is digital, i.e. 0 or 1
depending on the sampling of the curve and the value of the curve at that time.
Justin N:
From what i undrstood, Ppm itself isn't anolg or digital, its a means to carry compressed information. Ppm can be used with digital or analog signals so shouldn't it depend on the component generating the signals?
Michael M
Just to clear things up, it is a bit of *both*. PWM is digital in the sense that it is not using a continuous range of voltages to represent its value, but instead pulses between a low voltage and a high one (typically 5V in our receivers). In that regard, it is digital. But, the signal it is transmitting is transmitted as an analog signal, using the time between digital pulses to store the data. This part is definitely analog, because there is an infinite amount of continuous values that can be stored in between the two pulses.
The question began with an email I got from someone, and I was shown a screen grab from wikipedia:
I thought it might be interesting to see what other people think as i wasn't sure 100% myself
However here was what I replied.
The list you are referring to is modulation, which to my understanding, is how the signal is processed and sent out (conveyed).
Digital signals have characteristics such as discrete amplitude and discrete time.
PWM and PPM are both modulated in digital forms (square wave), but the signal is determined by the width of pulse (how long it's been up or down)... so it's not strictly a digital signal in that sense....
That's why I guess you can argue they are either digital or analog signal depends on where you are coming from
But when you are also comparing to signals like SBUS, then PPM is very much an analog signal to me
It's Digital!
Levi W:
Adriano D:
Martijn DK:
Sindre J:
Norbert T:
John L.:
Ole L.:
Forrest A:
Benedikt S:
Rick V:
Bob R.
Andrew M:
It's Both!
Eric Andreas S
Justin N:
Michael M
