22-Nov-2022, 01:52 PM
Hi folks,
New to the forum as i'm looking for some advice on my first build.
I'm using inav and since calibrating my Matek H743 wing FC it shows a negative value in the pitch of the aircraft when the nose is up, and conversely a positive value when the nose is down.
I assumed the pitch value should be positive when the nose is up?
Is this correct? should i calibrate the FC again?
Ive attached a screenshot to show the issue.
Many thanks
Pete
