I disassembled my tyro79: too small and too racing. I was after a more complex quad so i saved only motors and VTX and ordered a compass and a Noxe V1 with barometer.
The frame is a nice, light Kbat 136, i've enlarged the motor mounts holes to fit the 1607 motors...
Well i flashed with the latest firmware after an accurate welding job, i calibrated all the stuff and all seems fine, the issue is the rear right motor that stops when i use the throttle. (Dshot 150-300-600)
Trying Oneshot (125 & 42) the motors start to run in sequence (FR-RR-RL-FL) with the fourth that starts at full throttle.
Any Idea? Many thanks in advance.
here the "status", in attachment, the Dump
#status
System Uptime: 64 seconds Current Time: 2041-06-28T01:04:00.000+00:00 Voltage: 11.86V (3S battery - OK) CPU Clock=96MHz, GYRO=MPU6000, ACC=MPU6000, BARO=BMP280, MAG=QMC5883 STM32 system clocks: SYSCLK = 96 MHz HCLK = 96 MHz PCLK1 = 48 MHz PCLK2 = 96 MHz Sensor status: GYRO=OK, ACC=OK, MAG=OK, BARO=OK, RANGEFINDER=NONE, OPFLOW=NONE, GPS=OK Stack size: 6144, Stack address: 0x20020000, Heap available: 1828 I2C Errors: 0, config size: 6468, max available config: 16384 ADC channel usage: BATTERY : configured = ADC 2, used = ADC 2 RSSI : configured = ADC 3, used = none CURRENT : configured = ADC 1, used = none AIRSPEED : configured = none, used = none System load: 5, cycle time: 506, PID rate: 1976, RX rate: 49, System rate: 9 Arming disabled flags: RX CLI VTX: not detected
When you use dshot, each motor requires its own DMA assignment. In betaflight, you can check the DMA assignment by typing "resource" in CLI. But I not 100% sure how to do it with INAV. A DMA conflict is when 2 motors shares the same DMA. In betaflight, you can resolve the conflict by remapping resource, but I know you cannot do that in INav.
I will look into it more, on how INAV assigns the DMA for your FC.
Your problem might not be DMA conflict. Let do so troubleshooting. Can you spin the motor individually with the motor tab with oneshot and dshot?
It looks like the use of the NOXE F4 V1 flight controller with INAV is still work-in-progress which clearly still has some problems to be ironed out. See the following GitHub issue...
(11-Dec-2020, 07:16 PM)SnowLeopardFPV Wrote: It looks like the use of the NOXE F4 V1 flight controller with INAV is still work-in-progress which clearly still has some problems to be ironed out. See the following GitHub issue...
Then if you read the final post referencing the DSHOT issue (HERE) you will see that the person who submitted the pull request you linked to said he just released the FLYWOOF411 target with DSHOT enabled anyway, even though it appears to be troublesome. So there is no resolution to the problem in the currently released FLYWOOF411 target for INAV. One of us might be able to figure something out with a custom firmware build but whoever tries that really needs a NOXE V1 FC to test stuff with and I certainly don't have one unfortunately.
11-Dec-2020, 09:29 PM (This post was last modified: 11-Dec-2020, 09:38 PM by finnigan.)
(11-Dec-2020, 09:18 PM)SnowLeopardFPV Wrote: If you read from the following post downwards you will see that no-one managed to get DSHOT working successfully with 4 motors...
So if you had the FC, you think can make a functional custom firmware? (and MANY thanks for your kind aid)
