Inav Hardware Compatibility check
Hello, are these AIO compatible?
  1. JHEMCU GH743AIO 3-6S AIO Brushless Flight Controller 40A(BLHeli_S)
    JHEMCU GH743AIO 3-6S AIO Brushless Flight Controller 40A(BLHeli_S) [color=var(--primary-medium)]4[/color]
  2. Toothpick F722 2-6S AIO Brushless Flight Controller 35A(BLHeli_S)
    Toothpick F722 2-6S AIO Brushless Flight Controller 35A(BLHeli_S) – BETAFPV Hobby [color=var(--primary-medium)]1[/color]
If the board target is listed here then you are golden else your choices are to get a different FC or create your own custom INAV target which is not super hard especially if a target for that FC exists in Betaflight (but not everyones cup of tea).
(28-Aug-2022, 01:53 AM)kafie1980 Wrote: If the board target is listed here then you are golden else your choices are to get a different FC or create your own custom INAV target which is not super hard especially if a target for that FC exists in Betaflight (but not everyones cup of tea).
Hello Thank you for your response but even after making a custom target can it ensure all the features with smooth working?
Depends how well defined the custom target. Basically as long as you have the correct pins and hardware defined correctly it should all work. The functionality comes from the firmware side and so you cannot loose a function because of a custom target. But if you have defined the wrong pin/pad layout for a component on the board then then that component will not function.
Think of it as making "Custom defaults" for a target in Betaflight.
  iNav on NeutronRC AT32F435 mini AIO necbot 17 1,648 20-May-2024, 09:47 AM
Last Post: jirisvabik
  Recently flashed INAV to speedybee f405 and already had issues on quad crash. grozaalex 0 334 03-May-2024, 09:25 PM
Last Post: grozaalex
  Switch from BF 4.5 RC3 to INAV Maverick 0 212 19-Apr-2024, 08:44 AM
Last Post: Maverick
  Announcement INAV 7.1 - Compass No Longer Required SnowLeopardFPV 2 732 15-Apr-2024, 10:34 PM
  inav artificial horizon offset range quinn 5 249 08-Apr-2024, 12:38 AM
Last Post: StuweFPV
