18-Aug-2021, 05:56 PM
Hi there
i built two quads, both INAV powered:
one is a 4" Omnibus Nano v1, deadcat style frame, 1406-2600kv motors and 4032/4045 propellers. ESC Hakrc 25A, Eachine TCX23 switchable VTX, Runcam Hybrid.
Bn-180 GPS and an unknown, cheapQMC5883 compass, Oversky sbus rx for Flysky. A long multi antenna 3,3 Dbi.
This quad can fly well with LiPo 3s 850mah and with 4S LiOn pack 3500 Mah as well.
Weight 212 grams without battery.
The other one is a whoop, after some testing i definitively remove the ducts: too much noise and loss of performance due their 60 grs of weight to add to the total of 265 grams without battery.
Tha FC is a cheap but fully functional NOXE V1 + its matching 25A ESC, four 1507 3750 Kv motors, Eachine TXC 23 vtx, 3 DBi stubby antenna, Foxeer 1200tvl cam, FLI14 Flysky receiver. This one has a sporty attitude with LiPo 3s 850mah, but with the 4S LiOn pack 3500 Mah is a flying brick.
Now i'm ready for the first flights.
I have the same controls configuration for both Uavs:
sw1: ARM-DISARM
sw2: ANGLE/ANGLE+AIRMODE/ANGLE+ALTHOLD
SW3: ALTHOLD/POSHOLD
SW4: failsafe (landing)
sw5: BEEPER
sw6: RTH
I know, a weird setup but will help me to test the POSHOLD and RTH features without problems. (i hope)
so i need some tips:
- CONCERNING RTH LANDING SPEED(S) , In which scale are expressed? Cm/sec?. The default settings, works fine for a quad? If not, someone knows some good values for quads? Once landed, can i disarm the motors to stop them , they will stop by byself, or they will continue working like in "FAILSAFE LANDING" where i can set the stop delay?
- ALTHOLD AND POSOHLD PIDS AND TUNING. I read this:
PIDs affecting altitude hold: ALT & VEL PID meaning:
PIDs affecting position hold: POS, POSR PID meaning:
Really i don't understand.
-MC-BRAKING MODE! What is this stuff? Is a FLIGHT MODE or a feature? How it works? Needs a potentiometer or a switch?
-And the last question: how TURN ASSIST works? is something like the DRIFT in arducopter?
Thanks in advance for your interest.
sw1: ARM-DISARM
sw5: BEEPER
sw6: RTH
- ALT - translates altitude error to desired climb rate and acceleration. Tune P for altitude-to-velocity regulator and I for velocity-to-acceleration regulator
- VEL - translated Z-acceleration error to throttle adjustment
- POS - translated position error to desired velocity, uses P term only
- POSR - translates velocity error to desired acceleration
