Hi everyone,
Been fighting this for a few weeks but could not figure out why.
My setup:
iNav Firmware version 4.1
FC: Matek F722SE (s4 on the board was burnt, so using s5 on for motor #4)
ESC: Spedix L40 slim
ESC Protocol: Multishot
Motor #2 and #3 are reversed in BLHeli.
When I arm, the airmode will spin the motor; as soon as I move the throttle to about 10%, motor #1 and #4 start to increase speed out of control. The only way to stop them was to cut arm, bring the copter to pre-arm.
Here is the output of my diff all:
# INAV/MATEKF722SE 4.1.0 Feb 28 2022 / 13:50:01 (GITDIR-N)
# GCC-10.2.1 20201103 (release)
# start the command batch
batch start
defaults noreboot
# resources
# mixer
mmix 0 1.000 -1.000 1.000 -1.000
mmix 1 1.000 -1.000 -1.000 1.000
mmix 2 1.000 1.000 1.000 1.000
mmix 3 1.000 1.000 -1.000 -1.000
# servo mix
smix reset
smix 0 0 11 100 50 -1
# servo
servo 0 900 2400 1500 -100
# safehome
# logic
# gvar
# pid
feature GPS
feature LED_STRIP
feature DASHBOARD
feature PWM_OUTPUT_ENABLE
# beeper
beeper -RUNTIME_CALIBRATION
beeper -HW_FAILURE
beeper -RX_LOST
beeper -RX_LOST_LANDING
beeper -DISARMING
beeper -ARMING
beeper -ARMING_GPS_FIX
beeper -BAT_CRIT_LOW
beeper -BAT_LOW
beeper -GPS_STATUS
beeper -RX_SET
beeper -ACTION_SUCCESS
beeper -ACTION_FAIL
beeper -READY_BEEP
beeper -MULTI_BEEPS
beeper -DISARM_REPEAT
beeper -ARMED
beeper -SYSTEM_INIT
beeper -ON_USB
beeper -LAUNCH_MODE
beeper -LAUNCH_MODE_LOW_THROTTLE
beeper -LAUNCH_MODE_IDLE_START
beeper -CAM_CONNECTION_OPEN
beeper -CAM_CONNECTION_CLOSED
# blackbox
blackbox -NAV_ACC
blackbox NAV_POS
blackbox NAV_PID
blackbox MAG
blackbox ACC
blackbox ATTI
blackbox RC_DATA
blackbox RC_COMMAND
blackbox MOTORS
# map
serial 0 2 115200 115200 0 115200
serial 2 2048 115200 115200 0 115200
serial 5 262144 115200 115200 0 115200
led 0 7,4::C:2
led 1 7,5::C:2
led 2 7,6::C:2
led 3 7,7::L:4
led 4 7,8::G:0
led 5 7,9::C:9
led 6 7,10::C:9
led 7 7,11::C:9
# color
# mode_color
aux 0 0 2 900 1300
aux 1 51 2 900 1700
aux 2 1 2 900 1300
aux 3 11 0 900 1300
aux 4 10 1 900 1300
aux 5 5 0 1300 1700
aux 6 13 2 900 1250
aux 7 48 3 900 1700
# adjrange
# rxrange
# temp_sensor
# wp
#wp 0 invalid
# osd_layout
osd_layout 0 2 0 0 V
osd_layout 0 9 1 2 H
osd_layout 0 13 23 1 V
osd_layout 0 14 1 11 V
osd_layout 0 22 14 11 V
osd_layout 0 23 1 1 V
osd_layout 0 24 12 2 V
osd_layout 0 30 2 9 V
# master
set looptime = 500
set gyro_main_lpf_hz = 110
set gyro_main_lpf_type = PT1
set dynamic_gyro_notch_q = 250
set dynamic_gyro_notch_min_hz = 120
set setpoint_kalman_q = 200
set acc_hardware = MPU6000
set acc_lpf_hz = 102
set acczero_x = 50
set acczero_z = -86
set accgain_x = 4078
set accgain_y = 4057
set accgain_z = 4044
set rangefinder_hardware = VL53L0X
set align_mag = CW270FLIP
set mag_hardware = HMC5883
set magzero_x = -131
set magzero_y = -34
set magzero_z = 415
set maggain_x = 2798
set maggain_y = 2907
set maggain_z = 1801
set baro_hardware = BMP280
set serialrx_provider = CRSF
set blackbox_rate_denom = 2
set motor_pwm_rate = 2000
set motor_pwm_protocol = MULTISHOT
set failsafe_procedure = RTH
set motor_direction_inverted = ON
set model_preview_type = 3
set applied_defaults = 2
set rpm_gyro_filter_enabled = ON
set gps_provider = UBLOX7
set gps_sbas_mode = AUTO
set gps_ublox_use_galileo = ON
set airmode_type = THROTTLE_THRESHOLD
set osd_video_system = NTSC
set i2c_speed = 800KHZ
set name = XL8
# profile
profile 1
set mc_p_pitch = 44
set mc_i_pitch = 75
set mc_d_pitch = 25
set mc_i_roll = 60
set mc_p_yaw = 35
set mc_i_yaw = 80
set dterm_lpf_type = PT3
set heading_hold_rate_limit = 101
set d_boost_max = 1.500
set antigravity_gain = 2.000
set antigravity_accelerator = 5.000
set smith_predictor_delay = 1.500
set tpa_rate = 20
set tpa_breakpoint = 1200
set rc_yaw_expo = 70
set roll_rate = 70
set pitch_rate = 70
set yaw_rate = 60
# profile
profile 2
# profile
profile 3
# battery_profile
battery_profile 1
# battery_profile
battery_profile 2
# battery_profile
battery_profile 3
profile 1
battery_profile 1
# save configuration
save
Further testing shows that if I set the motor_direction_inverted=off, it would be motor #2 and #3 that would continuously increase RPM regardless of throttle input...
I am thinking this might be something basic that I missed, but couldn't identify anything obvious, might be that I am not looking at the right direction
I posted in the iNav github but later realized that maybe I should have put it here in this forum.
Any help is appreciated.
My setup:
batch start
defaults noreboot
# resources
# mixer
# servo mix
smix reset
# servo
# safehome
# logic
# gvar
# pid
feature GPS
feature LED_STRIP
feature DASHBOARD
# beeper
beeper -HW_FAILURE
beeper -RX_LOST
beeper -DISARMING
beeper -ARMING
beeper -BAT_LOW
beeper -GPS_STATUS
beeper -RX_SET
beeper -ACTION_FAIL
beeper -READY_BEEP
beeper -MULTI_BEEPS
beeper -ARMED
beeper -SYSTEM_INIT
beeper -ON_USB
beeper -LAUNCH_MODE
# blackbox
blackbox -NAV_ACC
blackbox NAV_POS
blackbox NAV_PID
blackbox MAG
blackbox ACC
blackbox ATTI
blackbox RC_DATA
blackbox RC_COMMAND
blackbox MOTORS
# map
led 0 7,4::C:2
led 1 7,5::C:2
led 2 7,6::C:2
led 3 7,7::L:4
led 4 7,8::G:0
led 5 7,9::C:9
led 6 7,10::C:9
led 7 7,11::C:9
# color
# mode_color
aux 0 0 2 900 1300
aux 1 51 2 900 1700
aux 2 1 2 900 1300
aux 3 11 0 900 1300
aux 4 10 1 900 1300
aux 5 5 0 1300 1700
aux 6 13 2 900 1250
aux 7 48 3 900 1700
# adjrange
# rxrange
# temp_sensor
# wp
#wp 0 invalid
# osd_layout
# master
set looptime = 500
set acczero_x = 50
set acczero_z = -86
set magzero_y = -34
set magzero_z = 415
set name = XL8
# profile
profile 1
set mc_p_pitch = 44
set mc_i_pitch = 75
set mc_d_pitch = 25
set mc_i_roll = 60
set mc_p_yaw = 35
set mc_i_yaw = 80
set tpa_rate = 20
set roll_rate = 70
set pitch_rate = 70
set yaw_rate = 60
# profile
profile 2
# profile
profile 3
# battery_profile
battery_profile 1
# battery_profile
battery_profile 2
# battery_profile
battery_profile 3
profile 1
battery_profile 1
save
