08-Jan-2021, 12:34 AM
I'm about ready to give up on this.
i have a flying wing that i want to add a compass even though i don't need it i can just use the GPS
but i plan on adding one to my 5" drone also.
i have a pyrodrone BN-880 Flight control GPS module w/ compass.
Flight controller is a Matek F405 Wing
my iNav settings:
Accelerometer is MPU6000
Magnetometer is HMC5883
Barometer is BMP280
Protocal is UBLOX
Ground Ass Type is: Autodetect
if i turn the Magnetometer off everything works fine in the setup window
right is right, left is left, up is up, down is down and yaw is correct.
in inav Setup:
heading is 0
Pitch is 0
Roll is 0
setting the "Board and Sensor Alignment" as shown below:
(My FC is mounted with front arrow pointing towards the left wing looking from the back of the model look to the front)
2.1 Roll Degrees
1.0 Pitch Degrees
270.0 Yaw Degrees
Default MAG Alignment
when i turn magnetometer back on, no matter what i change the "MAG Alignment"
to and i go back to "setup" when i move the wing the box in iNav will start to
rotate when i just move up, down, right or left.
reading iNav wiki on "GPS and Compass setup" is confusing and i tried changing
mag_align_x, y and z but don't understand how to get my heading to be 0 when
it is pointing north. and when turning the model N is north E is east S is south
and W is west.
i know this is alot but i'm been working on this for days, now i'm about ready to give up
on a compass.
Please if anyone can help or give me a phone number to call to get a person to talk to about
this or any help at all i would very much appreciate it.
Thank you
Jimv
my iNav settings:
Barometer is BMP280
Protocal is UBLOX
in inav Setup:
heading is 0
Pitch is 0
Roll is 0
2.1 Roll Degrees
1.0 Pitch Degrees
270.0 Yaw Degrees
and W is west.
on a compass.
Thank you
Jimv
