imax b6ac lipo charger (multiple charge)
Hey guys,
Quick question, I have an imax b6ac charger, that currently charges 1 battery at time.
Can I solder multiple connectors to charge batteries in parallel ?
If yes is there a limit in terms of number of batteries ?
I won´t be able to balance the batteries doing this I guess, but balance is something I usually do every 15-20 charges only.
Can someone confirm this is possible with no risk of damaging battery or charger?
Thanks
I would just get a cheap parallel charging board like this: https://www.banggood.com/Amass-XT60-Plug...50883.html
They have others under $10 depending on your connectors. If your charger is the 80W charger, you just have to be sure not to exceed power/current ratings. (Lots of youtube videos on this.)
  • flabombarda
You can balance charge batteries in parallel and you can connect as many as you like, it will just take much more time to charge them obviously
Thank you guys for the inputs.
Regarding the time taken, it isn´t a concern, the goal of this is just reduce the manual work of charging one by one. I can put them together to charge overnight and that would work just fine for me.
I´l buy this one from banggood, but it takes about 40 days to get in brazil, in the meantime I´ll build one to charge 3 or 4 at the same time, let´s see what happens !
You might check out Oscar's article: https://oscarliang.com/parallel-charging-multiple-lipo/
There are some safety considerations that you need to be aware of. (Batteries need to be very close in voltage before connecting, no mixing types, etc.). It's a good article.
Good luck!
(09-Jul-2017, 01:31 AM)flabombarda Wrote: Thank you guys for the inputs.
Please do not charge lipos unattended overnight when you are sleeping. It is really risky
[-] The following 2 users Like lorentz's post:
  • Drone0fPrey, unseen
(09-Jul-2017, 09:21 AM)lorentz Wrote: Please do not charge lipos unattended overnight when you are sleeping. It is really risky
Well said!
Waking up in the middle of a fire is not something you want to experience.
  • Drone0fPrey
  Charger Recommendation mblaide 2 127 24-Mar-2024, 05:31 PM
  GNB LIPO Eyes.fpv 9 331 02-Dec-2023, 09:30 PM
Last Post: Eyes.fpv
  some of my batteries no longer show up on my charger joetheslug 5 208 24-Sep-2023, 01:53 AM
  found multiple esc configuration blhelisuite32 niuk 5 414 25-Jul-2023, 01:46 AM
Last Post: ph2t
  LiPo battery bag recommendations stxrus 10 552 04-Jul-2023, 06:01 PM
Last Post: sevro
