14-Dec-2017, 09:54 PM
So I bought the Flysky i6s transmitter because I'm new and I wanted to use it for simulators. It should work great for that, however where I messed up is I wanted to also purchase a mini fpv quad like the Eachine 010s to practice maneuvers in real life. What I found is that the Flysky i6s transmitter is not compatible with that quad (only the regular i6 or i6x is) because it is AFHDS 2A and not regular AFHDS. Returning back to BangGood would probably be more trouble than its worth.
Are there any prebuilt mini indoor quads that I can use this transmitter for? If so I'm having trouble finding them. Should I instead look at building my own?
Thank you in advance for your help!
PS eventually I will buy the Taranis Qx7 as that seems compatible with a wide ranger of receivers.
