I need help with some oscillations
Hello guys. I just built my quad and I have some oscillation on yaw. The gyro isn't detecting any noise or anything but the yaw P goes bananas.
Should I just reduce yaw P? Can you help?
BB log:
https://drive.google.com/file/d/0B_O4bXy...sp=sharing
Workspace I used to see what's up:
Cli dump:
http://pastebin.com/xhmu3N93
Thank you all
Your yaw P term does seem to be a bit strong. It won't harm to try reducing it to 50 from the current 70 and seeing what difference that makes.
What does your quad look like?
Alright, thanks, I will try that.
And I forgot to post my setup
Frame: geprc zx5 (195mm X)
Fc: BFF3
ESC: Hobbywing 30a blheli-s
Motor: rs2205s 2300 kv
Prop: kingkong 5045 3-blade
Battery: 1300 75c 4s tattu
Ah, the ZX5!
I remember building mine. It was an insanely tight build and I'm still not happy with the fact that I ended up having to put the RX and VTX on top of the camera pod.
[Image: IMG_20170311_154834_zpspwlsbg0i.jpg]
It's a absolute nutter with 4S and 5045 bullnose props though. Extremely quick and really agile.
It is indeed crazy tight
[Image: YykUJnt0CVuWnxa-hJ0hlVGXOb9HiAtN0oEKrRyK...89-h950-no]
This is mine. I'm putting ws2812 leds on it right now
It did look like this, though Big Grin
[Image: 14448414_188975981528425_3584895754705043456_n.jpg]
[-] The following 1 user Likes varkokonyi's post:
  • fftunes
That makes me feel much better! Smile
What I'll probably do is swap out the VTX for one of the micro sized ones from Banggood. I reckon there's just about room for one inside the camera pod.
I use 5mm longer vertical spacers, makes the whole build much simpler Wink
yep lower yaw p it sounds a bit high.
  Help Pitch axis oscillations and hot motors Extrm 0 311 08-Jul-2022, 07:54 PM
Last Post: Extrm
  High throttle oscillations PistolPete 1 10,127 03-Nov-2017, 10:55 AM
Last Post: unseen
  Discussion Oscillations vs Vibrations Carl.Vegas 3 1,288 02-Oct-2017, 07:05 PM
Last Post: Carl.Vegas
  Help a newbie with propwash? Oscillations? aeroform 1 4,550 27-Jun-2017, 06:13 PM
Last Post: RENOV8R
  Strange oscillations a mid throttle... Gow864 9 8,620 15-Mar-2017, 06:22 PM
Last Post: Trail X
