Threads: 67
Likes Received: 711 in 472 posts
Likes Given: 1,216
23 I changed my FC in my ZMR 250 (X8R to XSR ...worked fine) and then I did some work on the video gear.....had an electric problem but it got fixed. So I went to fly the thing and I connot get telemetry from the FC (Naze32 rev6 full) I checked all the settings and I am getting battery voltage in CF. So I swapped it out with another board I had and now I get telemetery, but the board wont arm?!?!?! Two identical boards with identical configurations in the same machine, wired the same way and they do two different things????? The only thing I can figure is that both boards are bad, but in different ways. Thoughts/comments/advice??? Thanks guys.
Threads: 96
Likes Received: 531 in 218 posts
Likes Given: 188
20 on the board that won't arm, have you checked the status in CLI?
Threads: 67
Likes Given: 1,216
23 Not specifily for that, no. Before I started messing with it, I dumped the settings I was using in the board that was in there....which was working fine. I reladed those settings into both boards and now they don't act the same way? I'm befuddled. Now one thing I didn't mention....when I was working on the video gear there was a momentary short and I heard a slight pop and the video went dead. I found the problem and fixed it and although it wasent the FC, I'm wondering if it could have caused a slight surge and screw it up?
Threads: 67
Likes Given: 1,216
23 Problem solved...sort of. It just started working....no idea what I did, but I've probably got an intermittent problem that is going to raise it's head again at an inopportune time, I'm sure. Anyway...for now, if it ain't broken, I can't fix it. Thanks for your response Jimmy.
Threads: 67
Likes Given: 1,216
23 I "love" it until they "UNsort" themselves.........
Threads: 672
Likes Given: 2,030
139 For me these mysterious problems are normally caused by a loose cable/components somewhere.. Or solder pads half falling off
Threads: 67
Likes Given: 1,216
23 That's what caused the original problem with the video, a solder pad lifted. It was on the negative side so I just soldered a wire to the negative side of the voltage regulator output and tied that into the negative side of the VTX/cam circuit, bypassing the bad trace on the circuit board. I agree with your assessment, I've got something loose and I just haven't found it....yet. Thanks Oscar.
